Question about Frigidaire FSG748GF Dryer
What can i do about clothes getting stuck between the drum and the gasket on my frigidaire gas dryer model FSG748GFS1?
  • 10,319 Answers
Replace the seal between the drum and the front panel. This is a common occurance with the Frigidair dryers. The felt and rubber is made very cheaply
Posted on Jul 28, 2010
Why is the metal screen with round holes located in my dryer drum melting some clothes and leaving its impression on those clothes. My appliance is a Frigidaire gas dryer model # LAQG7011KBO.
The metal screen is the place where the heat from the dryer enters the drum. If the dryer is melting items, you have one of two possible issues:
  • The dryer thermostats are allowing the dryer to get too hot.
  • You are drying delicate clothes on too high of a heat setting.
Jan 14, 2015 | Frigidaire Dryers
Frigidaire Gallery dryer Model FSG447GHSO. Clothes and dryer sheets get caught between the drum and one of the three "bumps" inside the drum, causing burn marks on clothing. I can see the gap where it
There is a gasket that fits around the back side of the tumbler. Sounds like it needs replacing. It's job is to keep clothes inside the tumbler.
Oct 10, 2014 | Dryers
Clothes stuck in drum
You might have a drum glide, felt piece, that has come off or unaligned itself from the drum. Contact Frigidaire for one and replace it. You have too much of a gap in the front and that is why your clothing material gets caught.
Jul 29, 2012 | Frigidaire FEQ1442ES Electric Dryer
Clothes caught between drum and top of front panel: Frigidaire
You have a bad tub seal. It is glues onto the front panel...looks like a thick felt pad. Common thing on Frigidaire dryers.
May 21, 2010 | Dryers
Frigidaire FSGC747GE gas dryer is causing spots
you may need to replace the upper and lower drum felts, if they are worn, some of the clothing may be getting caught agains the drum and getting a mark on them. if the mark is like a pencil line mark it will be from the dryer, if it is more like an oil spot it will be from your washer. take a look at #20 & 21 in this picture.you may also need to replace the rear bearing which is #12 in this other picture. hope these help you.
Oct 24, 2009 | Frigidaire Dryers
My Frigidaire dryer makes a banging noise
What you have here is a drum bearing issue. Read my award winning essay on this subject right ova HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 09, 2009 | Frigidaire GLER642A Electric Dryer
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Frigidaire crown series dryer
The back of the drum has a hub (a flat steel piece with a shaft and ball) which allows the drum to turn. That ball rides in a plastic "cradle". Unfortunately on the crown series...if the ball and cradle are not greased regularly, the plastic wears. This allows the drum to "sag". The front end of the drum is lower than the back. You can confirm this by running your finger around the front of the drum. You'll notice that the top of the drum is almost flush with the body of the dryer and the bottom of the drum is 3/4 of an inch lower that the the body. This allows clothes to slip into the gap at the bottom and then they are spen to the top pof the drum were the lodge between the body and the top of the drum. The turning drum burns the clothing. Replace the plastic piece that the hub rides in.
Dec 28, 2007 | Washing Machines
Brown marks on clothes
This is a pretty common problem with these Frigidaire dryers. Crice hit it right on the head when he said the clothing is getting stuck between the guides and drum. The upper and lower felt guides need to be changed. This is not one of the easiest jobs. The top and front panel have to come off and the guides are glued on with high temp. adhiesive. The old guides have to be scraped off. Part numbers for the upper and lower guides are 5303937139 -(upper) 5303283286 -(lower). Catriver...post back
Jan 13, 2007 | Frigidaire GLER642A Electric Dryer
Dryers Logo
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
