Question about Kenmore Drop-In Bobbin 505S-21BH Mechanical Sewing Machine
I have the kenmore 385.18221 and I cant seem to draw the bobbin thread up. When I turn the dial the needle makes a clicking sound as it trys to bring the thread up but the thread doesn't come through. Is there something I'm missing or that I should be doing differnetly?
  • Kenmore Master
  • 7,365 Answers
1.make sure the needle is not bent --lay the needle on a flat surface & roll the needle over, if needle does not roll good then replace
2.make sure there is enough bobbin thread to pick up
3.make sure the needle is all the way up in the needle clamp
it sound like the needle is hitting the shuttle hook, if the steps above don't work then take it to be serviced
Posted on Jul 29, 2010
I just purchased a singer cg-550/500 and after threading the machine and inserting the filled bobbin, I was unable to bring up the bobbin thread with the needle. I followed the instructions carefully but...
if im not mistaken, the bobbin when you place it in the bottom, you have to thread it is as well to the part where the needle comes down and collects and goes back up. please re-look at instructions for placement of bobbin
Mar 05, 2011 | Singer Sewing Machines
It is threaded. but it goes through motion but there is no sewing.
Make sure that your bobbin is full and that you have picked up the bottom thread. Before you start sewing you should have two threads lying on the needle plate. To catch the bobbin thread, hold the needle thread and turn the machine by the hand wheel. The needle will bring the bobbin thread up with it. Pull the threads out about 4 inches and then you are ready to sew.
Feb 24, 2011 | Kenmore 15516 Mechanical Sewing Machine
Dont know if that its a q or not and cant figure out how to thread the bobbin
Make sure the thread is coming off the bobbin counter-clockwise, hold the end of the thread in your left hand, drop the bobbin into the case, and pull the thread into the slot at the front of the bobbin case by pulling it up and around the bobbin case to the left until you hear a click. That means the thread is in the bobbin tension. Then hold the needle thread in your left hand but don't pull on it; drop the needle into the machine and bring it back up by hand with the balance wheel, and as it comes back up, gently pull on the needle thread. That brings the bobbin thread up through the throat plate in a loop so you can pull it on out, and you're ready to go.
Feb 22, 2011 | Elna Quilter's Dream 6003Q
Top thread gets caught on crescent piece holding in bobbin case
If you have the manual take a better look at how to put the bobbin in the case,
sounds like you are putting it in wrong,
make sure you put the bobbin in with the thread com-ming off the bobbin in the right direction (left or right) if not put in the right way you will get what you are saying
ALSO: bring up the bobbin thread your self by turning the hand wheal and bring the thread a few inches to the back of the needle and hold when starting to sew the first 2-5 stitches.
when you do not hold the thread the machine will pull the thread in the bobbin area and cause problems.
you will get use to holding and it will get easier.
hope this helps
Sep 03, 2009 | Kenmore 15208 Mechanical Sewing Machine
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
I dont understand what it means by...
I beleive what they are asking you to do is to bring up the bobbin thread to the top of the throat plate( which cover the bobbin area, to do this you hold the top thread end and manually turn the wheel to engage the bobbin thread and bring it to the top of the throatplate, now you should be ready to sew
Maryann Sosewhappy
Dec 26, 2008 | Euro-Pro Dressmaker 998B
Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Dec 12, 2007 | Kenmore 15516 Mechanical Sewing Machine
How do you thread the machine, top and bottom, please.
From the Simplicity Sew Precious Model SWSP2 manual:
Inserting a new bobbin:
  1. Place wound bobbin into the bobbin case.
  2. Pull about 6 inches of thread out from the bobbin.
NOTE: Be sure that the bobbin rotates COUNTER-CLOCKWISE when thread is pulled.
  1. Pass the thread from the bobbin, under the bobbin case spring, and toward the back of the machine.
  2. Slide bobbin cover back into position.
Upper threading:
  1. Turn the handwheel toward you to raise the take-up lever to its highest position.
  2. Lower the presser foot.
  3. Place a spool of thread and spool cap on the spool pin.
  4. Place the thread into the first thread guide at the top of the machine.
  5. Bring the thread down the right slot of the threading path, then around the tension dial. Push the thread tension release lever and pull the thread up so the thread is secure in the thread tension dial.
  6. Bring the thread up the left slot of the threading path and through the take-up lever from right to left.
  7. Bring the thread back down the left slot of the threading path and into the needle eye from front to back. (Clip the thread end with sharp scissors fro easier needle threading.)
Raising the bobbin thread
  1. Make sure the presser foot lever is raised.
  2. Hold the end of the needle thread with your left hand. Turn the hand wheel toward you with your right hand until the needle goes down once and comes back up, stopping when the needle is at its highest position.
  3. Gently pull up on the needle thread. The bobbin thread, looped around the needle thread, will be drawn up through the needle hole.
  4. Push the thread tension release lever and pull about six inches of both the upper and lower threads toward the back of the machine, placing them under the presser foot.
You can obtain a copy in pdf format for free at:
http://www.simplicityhomecare.com/ftp/whitepapers/SWSP2-english.pdf
Dec 10, 2007 | Simplicity Sew Precious SWSP2 Mechanical...
Machine wont pick up bobbin thread
hi,try loosening your needle and pull it down a fraction then tighten it back up,i had same problem,good luck
Mar 11, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Bobbin
Hi Sally,
Don't forget to change your needle too. It may not look bent, but it probably is.
Nov 06, 2006 | Rex RX-1804
Kenmore Drop-In Bobbin 505S-21BH Mechanical Sewing Machine Logo
131 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
