Question about Maytag MSD2756G Side by Side Refrigerator
Frosting up im freezer compartment not getting cold
    Problem Solver:
  • 12 Answers
Check evaporator fan in freezer compartment if working check heater same compartment or defrost terminator
Posted on Aug 02, 2010
My refrezrator is not cool properly lg
Most fridges only cool the freezer compartment and the cold air then flows into the fridge section. It could be that the hole to the fridge from the freezer is frosted solid and no cold air can get through, if so, use a hair dryer to melt the frost and open the hole. It is usually near the bottom of the compartment.
Apr 05, 2014 | Home
The refrigerator is warm (55) and the freezer is cold (-5)
Sounds like a defrost heater has gone out. If the frost is in the back of the freezer, it will get worse and worse until it stops cooling. You can either unplug the unit for 12 hours, let all the frost melt and then turn it back on. Or replace the defrost heater.
Dec 05, 2012 | Refrigerators
Hotpoint (GE)CTX18GJB not cold enough. Just had serviced - tech replaced defrost timer and defrost terminator. The top located freezer gets cold and can hear the fan running - but still not cold enough...
I agree with the tech. if the refriderator isn't frosting it isn't working,their is only 1fan and its in the freezer,The tech could have missed some frost build up that is blocking the air flow into the fresh food section,if he removed all the frost it could take up to 24 hours to get cold ,it should slowly geta bit colder throughout the day,if by tomorrow its still not working have the tech come back and check for frost build up on the vents for air flow into fresh food compartment.
To reiderate their is two types of refrigerators,one that you have to manually defrost and a automatic defrost type where the defrost system which is comprised of the defrost heater,timer&termination t-stat will automatically melt the frost
Jul 28, 2011 | Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
Freezer developing frost and refrigerator not cold
check the circulation fan in the freezer compartment and make sure it is running.
Mar 13, 2010 | Refrigerators
Lots of frost in freezer
check your seals on the door and see if any on the compartments are broken because if the door is broken to the compartment it could be that the the cold and warmth is mixing causing your freezer to frost up temp could also be to high check all
hope this help
Dec 12, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My samsung is cold at the bottom of the fridge and warm at the top
Im assuming you mean the freezer is cold but the fridge is not . Most of the time these auto defrost fridges require a internal evaporator fan to draw the frost from the freezer to the fridge compartment. If the fan is stuck, it will not be able to transfer this frost. Before any major strip down, suggest you defrost fridge unit for approx 12 hours and start again. 90% of the time this will correct the problem. Almost certainly door was left open accidently for a period which resulted in this. Please let me know if not the answere.
Sep 24, 2009 | Samsung Refrigerators
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
Fridge not holding tempreture
if there is frost present on the rear vertical wall of the freezer compartment then the defrost function is broken and needs to be repaired the freezer is like an ice block and yo get cooling up to the refridgerator compartment air has to be able to flow and that can't happen if the frost is not eliminated
Dec 15, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Not cold enough
posible defrost not happening, air is not sirculating down to bottom compartment due to frost buil up
Oct 18, 2007 | Maytag MBF2256H Bottom Freezer...
Maytag MSD2756G Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
