Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
My Super Capacity washer fills but then stopsm,
My Super Capacity washer fills but then stops (water level selector apparently works) but the machine does not then continue to cycle through to agitate, spin or empty. Where can I get repair manual or expert directions to troubleshoot this problem?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jul 28, 2010
Heavy duty super capacity plus
Check water level switch and associated hose, see my other posts on this solution.
Aug 19, 2013 | Admiral AW22 Top Load Washer
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
I have an Admiral Heavy Duty Super Capacity 2 speed washer. It works great except that it takes forever to fill (3hrs!). I've taken to filling by hose each cycle. Am in a rental so don't have the...
low water pressure..... stopped up or kinked up water inlet hoses.......stopped up water fauset at machine......stopped water filter,s at machine ,,, or at water valve.......or bad elec water valve at machine
Mar 16, 2011 | Maytag Washing Machines
It does fill to capacity on the rinse cycle only on large or super levels.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 06, 2011 | GE WBSR3140DW Top Load Washer
Won't fill w/ water, Kenmore 3.5 Super Capacity Front Loader
The pressure switch is likely to blame. Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
My washer will not stop filling with water and overflows
Turn the washer on and let the water run, while the water is running unplug the power cord if the water stops the inlet valve is ok but if still running the valve is bad and need to be replace if the pump is good you need to test the water level switch, if faulty need to replace.
good luck
Mar 17, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Mar 16, 2008 | Whirlpool LSQ9030P Top Load Washer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
85 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
