Question about Health & Beauty
A water tank has steps inside it.a monkey is sitting on the topmost step.the water level is at the ninth step. 1.He jumps 3 steps down and than jumps back 2 steps up.in how many jumps will he reach the water level? 2. After drinking water he wants to go back. For thishe jumps 4 steps up and then jumps back 2 steps down in every move.in how many jumps will he reach back to the top step?
2 Suggested Answers
perpetually
  • 360 Answers
SOURCE: a well has 15 steps inside.the water level is at ninth steps.
It is a trick question sort of. The frog reaches water on the 6th jump before it has to jump back 2 steps for that turn.
Posted on May 15, 2010
Making coffee. Lost my manual.
Step 1
Warm your cafeti?re using some hot tap water and let it sit for a minute before emptying it out. Add two dessertspoons or a level scoop of Bewley's fresh ground coffee per person
Step 2
Pour in water just off the boil (equivalent to one mug per person) and stir to release all those fabulous flavours. Leave for 3-5 minutes to brew.
Step 3
Slowly plunge your coffee by pushing down on the centre shaft until the metal filter gently reaches the bottom of your cafeti?re.
Step 4
Pour your coffee then add milk and/or sugar to taste.
Step 5
Sit back, sip and enjoy!
myLightSmile
Dec 14, 2015 | Cuisinart DCC-2200 14-Cup Coffee Maker
We are having water leak from the bottom of our Roper Dishwasher door. THe model # is RUD5750DG3. I have taken the inside door frame off and found a small white rubber seal had dislodged inside. i...
Step 1:
Remove the service panel that runs along the front of the dishwasher just below the door. If it is screwed in place, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to remove it from the hooks.
Step 2:
Check the end of the drain hose that connects to the dishwasher. If it's leaking, tighten the clamp with a screwdriver.
Step 3:
Check the drain hose connection to the kitchen sink drain. Again, if it's leaking, tighten the clamp with a screwdriver.
Step 4:
221_a1.jpg Check for leaks around the water-inlet valve. If necessary, use an adjustable wrench to tighten the compression fitting that connects the water-supply line to the valve. If the fill hose is leaking, replace the spring clamp that is on the hose with a worm-drive hose clamp. It produces more clamping pressure. Use adjustable pliers to compress the spring clamp so you can pull the clamp and hose off the valve. Remove the spring clamp from the hose. Buy a worm-drive clamp at your hardware store, then install it and tighten it with a screwdriver.
Leveling the machine Step 1:
Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
Step 2:
Open the door completely and remove the bottom dish rack.
Step 3:
Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
Step 4:
Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
Step 5:
Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
Step 6:
Reattach the dishwasher to the countertop and reinstall the front access panel.
Fixing a leaking door Step 1:
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
Step 2:
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Step 3:
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Step 4:
Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
Step 5:
Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
Apr 06, 2008 | Dishwashers
NEED TO KNOW HOW TO MAKE COFFEE.
Step 1
Step 2
Step 3
Step 4
Step 5
How do I increase the water flow into the tank of a Verona toilet
1.) Check to make sure that the water shut-off valve is all the way open (the water valve a.k.a. the shut-off valve is located behind the toilet near the wall or the floor, depending upon installation placement.) The water supply line attaches to it and feeds up into the refill valve assembly inside the toilet tank.
2.) Check the float assembly or the refill valve assembly, make sure it hasn't bound up by getting caught on another part inside the tank.
3.) Check the water level to make sure that it sits about 1 inch below the overflow tube in the middle of the tank. If the water is lower, adjust the float inside the tank to raise the water level. For models that have a ball float, turn the screw on top of the fill valve clockwise to raise the water level. For models that contain a cylinder float valve attached to the fill valve, squeeze the clip on the side of the float and pull the float up until the water reaches the desired level.
Feb 17, 2015 | Home
Need to increase bowl water level. how do I do that
Step 1:
Remove the top lid of the tank, ...carefully, so as not to break the ceramic by dropping it on the floor accidentally. Inside exists a "lever" attached to a "float" acting as a "fulcrum," with the "float" resting on the level of the water in the tank. The more water in the tank, the more water will enter the bowl, at flushing time.
Step 2:
The level of water in the tank corresponds to the level of water entering the system upon flushing the commode (bathroom fixture). At the bottom of the tank exists a "flap" type of device (usually). As the water exits the tank into the bowl the flap seals off again, discontinuing the water's entry into the bowl. This should always seal off at the end of a "fllushing cycle." The more water in the tank at the beginning of the flush, the more will enter the bowl.
Step 3:
Therefore, raise the arm of the "lever" (sometimes it's a "vertical" post with an "adjustable float" on it; in what case one raises the float on the post, by depressing a "clip" like device on the float itself, sliding it up versus down) by bending the arm upward, ...carefully. The increased water in the "tank" by the above process should solve your problem. Be certain to note whether the "flap" closes prematurely (It shouldn't), adjusting the flap's "chain" (held up by the "handle" itself) should it close prematurely.
Step 4:
You may need to tighten the "nut" (fastener) on the "handle" inside the tank as the "chain/flap" may simply be closing prematurely, because it's "loose" (easily tightened by hand at times, versus with a small, adjustable wrench bought at a "hardware store" like "Ace Hardware").
Step 5:
The above items (one, versus several of them), should solve your problem.
Jan 19, 2013 | Jacuzzi Bath Maxima EL61 959 White...
Water level after regen is over half the way up the brine tank
The eductor assembly is plugged. This will cause the unit to not draw brine but will keep re-filling salt tank causing high water in tank.
Take the cover off the control. On the left side of control there is small dome shaped apparatus. The"eductor assembly" is inside here. By-pass the softener, run it through a quick regeneration (to depressurize the system) Hold the regen button down until it starts through cycle, then push regen to cycle through each step of regen until it goes back to service. You will see this (S) on top of the valve where the main drive gear is.
When depressurized, take the lid off the eductor housing, disassemble and clean all the small holes completely. Be cautious of small nozzles and small screen in system as they can be easily lost.
Re-assemble, put water back to unit. Run through manual cycle again.
1. Refill
2. Backwash
3. Brine draw
4. Rinse
Then advance to backwash and let system go through complete regeneration.
You will have to bail most of the water out of salt tank as it will never draw it back down to proper level with that much water in tank. About 4" of water.
RJ
Jul 28, 2011 | General Electric Company 45000 Grain Water...
A well has 15 steps inside.the water level is at ninth steps.
May 15, 2010 | Answer Carbon Expert BMX Handlebar
Dishwasher leaks water as it fills
  • Step 1 Remove the front access panel (see step 1, "Tightening the fittings"). This will give you access to the dishwasher's adjustable feet.
  • Step 2 Open the door completely and remove the bottom dish rack.
  • Step 3 Unscrew the dishwasher from the kitchen countertop so the dishwasher can move freely as you adjust the feet.
  • Step 4 Check to see if the dishwasher is level side to side. Place a small level inside the dishwasher so it's sitting on the bottom pan and facing parallel to the front lip of the dishwasher. If the dishwasher is not level, use adjustable pliers to turn one of the dishwasher's front feet up or down until you hit level.
  • Step 5 Check to see if the dishwasher is level front to back. Turn the level perpendicular to the door, and place it on one of the bottom ledges that run along the side of the cabinet. Check the level again. If the dishwasher isn't level, use your adjustable pliers to turn the back feet up or down until you hit level.
  • Step 6 Reattach the dishwasher to the countertop and reinstall the front access panel.
  • Step 1 Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
  • Step 2 If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
  • Step 3 Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
  • Step 4 Pull the old gasket out of its groove, using adjustable pliers (see illustration). Take the gasket to an appliance store to get a replacement.
  • Step 5 Soak the new gasket in warm water to soften it, then press it into the groove. Start at the top, then work your way down the sides and across the bottom.
  • May 14, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
    Getting raft back
    First step: Move 1 wolf and 1 chick
    Second step: Bring 1 chick back
    Third step: Move 2 wolves
    Fourth step: Bring 1 wolf back
    Fifth Step: Move 2 chicks
    Sixth Step: Bring 1 chick and 1 wolf back
    Seventh Step: Move 2 chicks
    Eighth Step: Bring 1 wolf back
    Ninth Step: Move 2 wolves
    Tenth Step: Bring 1 wolf back
    Eleventh Step: Bring 2 wolves over
    That's it!
    Mar 23, 2009 | Nintendo Professor Layton & the Curious...
    Crossing of wolves and chicks
    Hi, try this bro!
    Eleventh Step: Bring 2 wolves over Take the 3 wolves first kick them until they run away go back and take the chicks across (That is if the wolves havent killed you)
    Nov 23, 2008 | Nintendo Professor Layton & the Curious...
    Health & Beauty Logo
    169 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Marvin
    Marvin
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
