Question about SanDisk 2GB microSD Memory Card
Where to install memory card
I have a SanDisk 2 GB memory card and full-size adapter that I received when I got my Verizon blackberry. I don't have a clue how to use it...Where is it installed?
  • 37 Answers
Depending on your model of Blackberry the memory card will either fit in a slot on the side of your phone (under a cover) or if you remove the battery you will see a slot for the card. The full size adapter is so that you can read the card in a standard memory card reader plugged into your PC.
Posted on Jul 28, 2010
I have a 32GB sandisk and it says its full its brand new
If the file size you are trying to transfer on to the flash card is greater than 4 GB, it will not transfer unless it can be divided up. This is because the flash card by default is formatted 32 bit. The maximum file size in theory should be something like 4.294 GB (going from memory).
Re-format the card in NTFS, if the particular card type will allow this. Not all the cards can be formatted in NTFS. This way you should be able to put files on the card that are greater than 4 GB in size.
Jerry G.
Sep 08, 2012 | SanDisk Cruzer Sdcz36-032g-b35 32 Gb Flash...
How do i save info to my new sd card
Under your blackberry system settings, storage/memory options you should be able to choose the SD card instead of the internal memory.
Mar 15, 2011 | CCM Cellular SanDisk 4GB Class 2 microSDHC...
Sir, i had got 2 gb sandisk micro sd card.i had forgotten the password for it,can you please help me on this matter,please tell me how i can unlock my micro sd card.
I am unaware of any password associated with this type of memory card. Are you using it in an adapter to make it fit in a full size SD card slot? The adapter may have a switch on it to write protect the memory, although the micro card itself does not. If that is the case, take the card (adapter and all) out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Oct 30, 2010 | Cameras
How don i back up my contacts on my blackberry storm using the sandisk 2GB stick?
select all contact and go to OPTION then select COPY TO MEMORYCARD if they are not enebled copy to your SIM card
Jun 26, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Blackberry Flip won't read memory card anymore
Make sure you have the right sized media card for your device OS:
BlackBerry Device Software 4.2.0 Up to 2 GB BlackBerry Device Software 4.2.1 Up to 4 GB BlackBerry Device Software 4.2.2 Up to 4 GB BlackBerry Device Software 4.3.0 Up to 8 GB BlackBerry Device Software 4.5.0 Up to 8 GB BlackBerry Device Software 4.5.0.81 and later Up to 16 GB BlackBerry Device Software 4.6.0 and later Up to 32 GB
http://supportforums.blackberry.com/rim/board/message?board.id=8300&message.id=18217&query.id=64220#M18217
May 10, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
SanDisk Memory Card
If ur card is over 2GB, the memory card reader may have a max memory size limit. if it does it is probably 2GB. Check the specs or try a smaller size card to test.
Dec 08, 2008 | SanDisk 2GB microSD Memory Card
Message "Not enough memory" with Blackberry
have u change the storing place fm internnal memory to storage ?
Jun 02, 2008 | SanDisk 2GB microSD Memory Card
Cannot add music onto blackberry curve 8310 with sandisk 1 gb memory card
pls format the card from the blackberry device.
this should take care of the issue
Feb 27, 2008 | SanDisk Memory Media
1 GB MICRO SD TRANS FLASH MEMORY CARD AND ADAPTER
hi,
what is the brand of ur flash memory card. some doesn't get recognized in OS lower than XP.. you might need a driver for it... knowing the brand would help.
regards.
bzoy
Jan 09, 2008 | SanDisk Memory Media
SanDisk 2GB microSD Memory Card Logo
126 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
