Question about Fuji FinePix S5000 Digital Camera
Camera is a fujifilm wide zoom 4x 8.2mega pixels
Camera is a fujifilm wide zoom 4x 8.2mega pixels fine pix photos were deletedaccidently and are in the internal memory I don't understand ?
  • 8 Answers
SOURCE: Zoom Error
Pull the lens away from the body until it clicks and then turn it clockwise while looking at the front of the camera.
Posted on Dec 29, 2007
jackboy
  • 2985 Answers
SOURCE: Megxon C480 Digital View Camera
I regret that there is no repair option in general for this type of thing.
Replacement is the only option
Posted on Jan 02, 2009
t00nz
  • 4738 Answers
SOURCE: Zoom Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Apr 18, 2009
  • 11967 Answers
SOURCE: Hello my barely used fujifilm fine pix J38 camera zoom error mess
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 03, 2010
  • 906 Answers
SOURCE: My camera is a fujifilm fine pix xp10. i droped
Good day Sir, here's the link below and you can read on that the users manual try to check it.
manual
Posted on Jul 26, 2010
Fujifilm fine pix f20
There is software you can purchase in an attempt to retrieve your photo's go to www.ebay.com Type: picture recovery a list of sellers will pop up to give choices, also check www.download.com and type same notation.
Apr 22, 2012 | Fuji FinePix F20 Digital Camera
How do you delete photos from a Fuji jx250 digital camera
Connecting you camera at pc and check as external device, sleect and delete or formatting the card in the camera will erase all of the pics at once.
Hope helps.
Mar 22, 2012 | Fuji Cameras
I have a Fujifilm 4.1 mega pixels Fine Pix digital camera which all of a sudden says on the screen "card not initialized" there is no place on the menu to reset it....can you help? Thank...
"Use the right arrow to get the "options" menu, use the up arrow (zoom in button) to select "set-up", press "menu/ok". Use the down arrow to select "format" on the menu, then (making sure you have selected "OK" on the options available on that screen) click "menu/ok"." -- annabellafitz
Mar 07, 2011 | Cameras
I have ixus 950 IS. Plz tell me why the picture become hazy when I use zoom more than 4x though there is provision of zooing upto 16 x.
The optical zoom goes to 4x but then the camera shifts into digital zoom. Sounds like you need to increase your resolution (fewer pix/mem card or more megapixels per photo) in order to reduce the fuzziness. On the other hand, it could be a problem with you specific camera. If it is still under warranty, ask Canon if this is normal...it may be covered if it is a quality problem. Once you get into the digital zoom range, the quality of the pictures will decrease with any digital camera.
Jun 25, 2010 | Canon PowerShot SD950 IS Digital Camera
Sony ericsson g502 wont camera wont zoom
Just check the Mega pixel setting of your phone . You will find that setting in your camera settings. just lower the pixels and You will be able to zoom the pics.
Dec 11, 2009 | Sony Ericsson K750i Cellular Phone
THE DIGITAL ZOOM APPEARS NOT TO WORK. MAGNIFYING TO 16X CAUSES A BLURRY PIX, IN BOTH VIEWER AND PHOTO. DO NOT THINK THIS IS A RESULT OF ANY FUNCTION SELECTED.
Digital zoom magnifies the pixels to seem like you're getting closer to the subject but you're not. The larger the pixels, the worse the picture will look. You should never use the digital zoom (most people disable it). Only use the optical zoom.
Oct 16, 2009 | Canon PowerShot SD850 IS Digital Camera
Zoom Error
I'm not sure if this will work as I have yet to try this for my self. But according to others who have had this problem pulling lens out while camera is off and then restarting camera works. If this does work please notify. Or just tell me what happens when this is done
Aug 03, 2008 | Pix FUJIFILM Fine S1500fd Digital Camera
Fuji FinePix S5000 Digital Camera Logo
101 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
