Question about Daewoo KOG-867T Microwave Oven
Microwave sparks inside oven in the area of the sealed compartment when it is started
    Problem Solver:
  • 3 Answers
If unit was run for long time with food on walls and not cleaned off, it is possible that the unit was burned in a spot where the food was and if there is metal frame under that part for the finish it will spark. Check closely for burns, if it is sparking due to that problem, junk it. It is a dangerous condition.
Posted on Sep 23, 2010
GE Microwave oven is making popping sounds.
This is because the coating inside the oven or the wave guide has been damaged and microwaves are hitting bare metal and causing sparks. Take the light bulb out of it and when it is dark, put a glass of water in it and turn it on. If you can see the sparks then you know what needs to be repaired. You can buy microwave oven paint. It is special paint though, you cannot just use any paint. If you cannot see sparks then the area that is damaged is inside the unit and it should be taken in for repairs. If you don't fix it, it will blow out the magnetron and you will be looking at a new oven.
May 24, 2015 | GE Microwave Ovens
Change spark
Check diode and capacitor. Instructions should be found inside the unit.
Nov 11, 2017 | GE Advantium SCA2001BSS Microwave Oven
GE Spacemaker XL1800 sparking from behind wave stirrer cover
Microwaves use a magnetron to generate microwave energy and direct it a rotating blade wheel to spread them around the inside of the oven. If there is any metal in the area to be heated, or any of the blades are bent, even a bit, the microwave energy can be reflected back up to the magnetron area. In this area there is now too much power and it sparks away, so it does not heat the item in the oven.
Because it is sparking it is now a safety hazard the sparks may melt and set fire to plastic parts in it. This is serious it could burn your house down. Bin this microwave and cut the cable off it to make sure no one else ever uses it.
Dec 20, 2013 | GE Profile Spacemaker JVM1871 Microwave...
It sparks
Check splatter shield inside cooking area for burnt carbon ie replace
Dec 11, 2013 | Panasonic NNSD688S 1.2 Cu. Ft. Capacity...
My GE microwave convection oven JVM1790SK 01. It has started to make a load grinding noise, and is sparking above the cavity area, otherwise it operated properly. When I remove the fan assembly part...
The fan is for air circulation regulation, e.g. preventing steam (and smoke) from building up inside, and also stops air pressure from building up inside so you won't get a blast of steam coming out or worse. On the convection side it heats the food faster and more evenly. You will need to replace the fan assembly to keep the microwave safe. the noise and sparks are probably due to spent bearings and / or a dislodged fan scraping against another surface or something getting in the way of the fan
Nov 30, 2017 | GE JVM1790 Convection / Microwave Oven
Our kitchenaid microwave, sparks when we turn it on.
If the sparks are happening on the inside of the microwave's cooking area while you are cooking, then make sure you clean the inner surfaces really well. Be sure to remove any cooked on food particles that may have splashed up during cooking.
If the cleaning does not work, you may need to replace the waveguide cover. Click on the following Youtube video link for an instructional video on the process:
http://www.youtube.com/watch?v=M0xsXjhefy4
If the sparks are coming from somewhere other that the cooking area, then your unit may need more significant electrical repairs or service.
Thank you very much and good luck.
Mar 30, 2011 | KitchenAid KHMS147HS Microwave Oven
My LG microwave is making sparks near the door seal . how can I fix it?
the metal probaly exposed due to corrosion clean the area properly buy a tin spray note must be heat resistant and retouch the area that should help.
Oct 21, 2010 | Microwave Ovens
Sparks in microwave/convection oven
Remove the plate and clean it with warm water
Jun 22, 2009 | Panasonic Microwave Ovens
Problem
check halogen light holder and connections, and any damage body, check inside body of microwave oven , because of microwaves some sparks comes from damaged body..
Oct 18, 2007 | Kenmore 63793 Convection / Microwave Oven
Daewoo KOG-867T Microwave Oven Logo
222 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
