Question about Dometic Rooftop RV Air Conditioner
Air conditioner The air conditioner & fan stopped working. The fuse at the circuit breaker panel is good. Is there a fuse or reset on the unit itself ?
    Novelist:
    Champion:
  • 246 Answers
There is a fuse inside the control panel of the AC itself. You have to take the cover off (from inside on the ceiling) and look up in there with a flashlight to find it. It is usually a very small amperage fuse - I think a 1 or maybe a 5 amp.
hope this helps
good luck
Posted on Jul 29, 2010
Cannot get ANY of the fans to work.
one half of the breaker you moved is not making contact in the panel or moving the breaker caused the fan relay to be on the same 115 volt leg as the power leg. If the breaker is connected to two points in the panel and you have 115 volts on each side of the breaker (230 volts) You can move the breaker one notch higher or lower or switch wires on the breaker to correct the circuit.
Oct 12, 2014 | Heating & Cooling
Problem with Air Conditioner
there will be an access panel where the motor is located. 1st thing to check is fuse or circuit breaker feeding the air handler. this is on seperate power from compressor unit outside and usually has a fused or breakered disconnect on the side of the unit. if fuses are good or breaker is not tripped then switch fan mode to on. if blower runs in on but not in auto then it is a thermostat problem. if still no go then turn off power, remove access panel and find the squirrel cage fan blade. make sure it turns freely. it is very common for these motors to go bad. it can usually be removed easily and taken to a motor shop. I use Roy's Electric in Richmond, Va. They can test the motor on the bench and replace it if it is faulty.
Sep 08, 2012 | Heating & Cooling
After a thunder storm my roof mounted Carrier cooling/heating unit stopped working and now does nothing. Changed the time delay fuses and checked the circuit breakers and they seem fine. Is there a reset...
You may have a circuit board problem. Make sure you have power to the unit first. If you can, get on the roof take the access panel off to the electrical components. Most carrier circ boards have a flashing light display on the board itself. On the back of the panel you just took off should be a kiosk that tells you what the flashing means. If the light is dead, no color but you are sure there is power to the unit, the board is bad or there could be a fuse blown on the board. Most circ board fuses are a small 3 or 5 amp blade fuse mounted right on the circ board. I have seen many a carrier board burn out because of lightning. I hope this is not the case for you, as carrier boards are just a little expensive. Hope this helps you get some air back. Mark
Aug 01, 2011 | Heating & Cooling
Unit has faint hum but no compressor motor or fan workin
Check the fuses and breakers. If there are fuses, they will be in a small box mounted on the outside near the outdoor unit. You will have two fuses in a cartridge that your local hardware store will check for you.
The circuit breakers may be in the main breaker panel in your house . There will be two and more than likely they will be clipped together. Push them all the way back and then all the way forward to reset. If the breakers aren't marked, they will be 30 amp to 50 amp depending on the size of the unit.
Hope this helps, stay cool. mark
Jun 29, 2011 | Heating & Cooling
Does the 15100 Kenmore BTU need a dedicated line in order to not blow a fuse?
Is this a 120 volt unit? If so, you might try to find the amp rating on the unit itself. A 120 volt unit that big will have to have a circuit all by itself. Probably a 20 amp breaker, no less than 15 amp just for the air conditioner.
If it is 240 volt, it will definitely have to have its own circuit.
Jun 21, 2011 | Kenmore Multi-Room Air Conditioner
First time using my air conditioner after winter. my "inside" fan will run but the outside unit is not starting. My weather king is approx 9 years old
Check fuses and circuit breakers to the outdoor unit. Fuses should be right next to the unit in a box on the side of the house. Easiest thing to do is replace them both. Circuit breakers are in you circuit breaker box. There will be two of them, probably 30 or 40 amp maybe 50 amp if a big house. Trip breakers all the way back and then all the way forward. Hope this works.
May 11, 2011 | Heating & Cooling
AC unit GOODMAN modelGSC130421AC was working good and today stop working the fan work but the compresor dont start
Check your circuit breakers and fuses. If it tripped breakers or blew fuses it may be because the outdoor coil is stopped up with dirt. If it is wash it out real good with a water sprayer.
May 10, 2011 | Heating & Cooling
I have a Samsung Ductless Air Conditioner. It wil...
i think there is a short circuit in the fan or compressor even in the board.loop check it & say how many amper is there?
May 21, 2010 | Samsung AS18A6RB Air Conditioner
Is there a reset for the a/c unit itself
check for fuses in disconnect at the out door unit or a reset button where the copper line set goes into the unit at make sure stat wires have not been damaged hope this helps
May 15, 2009 | Weather King 10AJA4201AH Air Conditioner
Not working
If the indoor fan will not run it one of two things. Breaker to furnace or a bad 24v transformer. Thx RepairUSA
Sep 30, 2007 | Ruud UAMB Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
686 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
