We do not have cable or satilite hooked up on this t.v. We go to program the channels and we get all ditital chanels. We have a antena hooked up that is for stand alond counter type t.v. rabbit ears. The problem is that when we go to channel 4 here in Dallas. We cant get this channel. When we go to the regular air channels 4 through 37 they dont come in good at all. do we have an incorrect antena or what. This is model DP19657. The antena is RCA high proformance off air HDTV. What do i need to do to get good recievtion on regular channels or how to get channel 4 on the ditital channel.
  • 121 Answers
The newer TV's require you to go through 'setup' in the menu section. It should allow automatic antenna search.
Posted on Apr 24, 2008
How can i program the chanels with only HDTV antena?
On the initial set up screen choose air on the tuner select line then do an automatic channel search.
Nov 02, 2015 | Sansui COM312AD 13" TV/VCR Combo
Its getting better, i now have a picture & sound, but on one chanel only, i cant get any other chanel
With the remote go to input or source or menu,Select tuner,
select antena air or cable,select search channels and wait.
Flat panel?
Nov 05, 2012 | Televison & Video
Lc329slx sylvania tv couldn't scan any chanel from cable
If you were using an antenna before make sure the set is now set to CATV or cable before trying to program the channels.
Jun 01, 2012 | Sylvania LC320SLX 32 in. LCD TV
Does emerson model #20s5b have a switch to convert from cable to satilite?
It's in the channel programming menu. It should say, "Cable/Ant" or "Cable/Air" If you want a roof antenna with local channels, change it to "Air/Ant" Then click auto program with the antenna hooked to it to scan for free local channels.
Jun 16, 2011 | Emerson Televison & Video
I don't understand the manual! How do you get any channels tuned in on the Technika LCD19-910
on all tvs there is a menu pannel find the menu button on the remote or tv could also be called setup button look for channel option or antena cable option (no on most of the new tvs it is an auto scan) and select that option it will scan throught the channels and auto add the ones that get reception say if ur using an antena
if u are trying to hook up a cable box or sat box through the antena coail wire at the same time u can not have them on so to scan for antena channels turn off the sat recver and cable box scan for channels because the sat box and cable box destors the singnal when on the same time with the antena u will proble have to go back into the main menu where yu selected the channels and manualy add channel 3 or 4 which is what runs the sat/cable box if ur using the antena hookup on the tv
if u are hooking the sat/cable box or dvd player to red gren blue or yellow white red hook up's they will be under a diffrent source chanel which u can usaly get to by hitting the input or source button on the remote
Jan 15, 2011 | Televison & Video
Our cable was turned off today and we get no channels on our tv. Shouldn't we be able to pick up some analog channels?
If you have an extenal antena and your tv is digital you should be able to get local chanels. If you dont you can get a converter box about $35.00 and get a good external antena that should do it.
Thanks,
Dec 18, 2010 | Vizio Televison & Video
I do auto programing some chanels get program some don't
Hello
Check first your set top box's, or TVs antenna or ariel connection is tight or not. It it is Ok, if you are receiving signals from cable, ask the cable operator to check the signal strength at the cable end of your home. It is measure with a 'db' meter. If the strength of the received signal is very weak, the same channels should not mamorized, and strong signal channels only will lock in. If you are using external antena, try to reorient its postion.
Anyway your TV doesn't get sufficient signal strength.
Oct 19, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Cannot receive channels past 99
Is this free over the air signal?Get a better antena like a roof antena or digital antena.Rescan again after everything hook up.If this Cables,satalites,or telecom signals,unplug,replug the box for bootup and software
upgrage,go to ur tv menu make sure it on cable setting,rescan it again to get all fresh channels.
Nov 04, 2009 | Symphonic ST420FF 20" TV
Converter boxes hook up
u need a stronger antena , best check without the converter box and see if u get chanels , if u do hookup the antena to the converter box then to the tv and do the scan again , move the antena to diferent places
May 01, 2009 | Funai Trutech 13" TV
Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
