Question about Dishwashers
Beko/leisure dwlt65 is not filling with water
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: my leisure dwlt65 dishwasher keeps switching its self off when going till wash
see this causes and fix it. God bless you
Touchpad and Control Panel If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been have ruled out, the main control board might need to be replaced.
Posted on Sep 29, 2012
The power button is crackling when i turn my Leisure DWLT65 dishwasher on. is it the power switch?
Hello. Here is the link to the power button for your unit. Most likely, the contacts inside the switch have worn out causing arcing--hence the crackling sound you heard. I would not use the washer until you get the switch repaired! If the internal contacts are not touching properly, heat will be generated and could cause the switch to melt, thereby creating a real safety hazard(I've seen this happen). Leisure DWLT65 On Off Power Switch I hope I helped you!
Feb 23, 2015 | Leisure Dishwashers
Why beko dishwasher wont fill with water
Assuming you can select programs and start it, the most likely problem is water inlet valve. Make sure the water tap under kitchen sink is open.
The water inlet valve looks like this.
Beko DS1054S Solenoid Valve
Sep 03, 2014 | Beko DS1054S 450 mm Silver Freestanding...
Not emping water
This is a generalize answer, but remove the bottom kick panel to manually rotate the pump motor. In general they can get locked up by objects. Locking up the pump.
May 26, 2014 | Leisure DWLT65 Dishwasher
Dishwasher will not start after being switched on- can you help
Here is the link to the power button for your dishwasher: http://www.amazon.co.uk/Leisure-DWLT65-Off-Power-Switch/dp/B00O470CVM. I hope this helps you!
Jan 03, 2014 | Leisure DWLT65 Dishwasher
My leisure dwlt65 dishwasher keeps switching its self off when going till wash
Sep 28, 2012 | Leisure DWLT65 Dishwasher
Beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
Feb 23, 2012 | Beko Washing Machines
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
125 people viewed this question
Top Dishwashers Experts
