Question about Jura Capresso Jura Ena 5 2Cup Coffee Maker
I have a Jura Capresso Ena 5 Coffee machine. Quite often
I have a Jura Ena 5 Coffee machine. Quite often there is water underneath it. This seems to be coming from the water tank. How can this be fixed
Thanks
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the issue.
Thanks.
Posted on Aug 02, 2010
  • rko2944 Aug 02, 2010
    Water seems to be slowly leaking out of the machine as every few days there is a small pool of clear water (not coffee) near the base of the machine. If I then move the machine, there is a puddle of water underneath it.
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Jura ena 3 rotary dial issue
Have you tried completely powering it down, as far as unplugging it from the wall? Sorry if that's stating the obvious, but I'm a computer guy and 9 times out of 10, a 'reboot' fixes the problem.
Aug 04, 2014 | Jura Capresso Jura Ena 3 Espresso Machine ...
Close cover message
the same here, but with jura impressa j5. any solutions?
Feb 08, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Service manual cva620
http://elektrotanya.com/miele_cva620.rar/download.html Try there All the best Kolbrun
Sep 18, 2013 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
How to open for cleaning jura ena5 coffee machine
The question is, how to open the machine? I found elsewhere one should unscrew the back logo, but it is slippery. Seems like a special tool would be needed, but I did not find it.
May 06, 2012 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Ena 3 troubleshooting: Right now it appears that the right coffee spout has a weaker flow than the left. Is it clogged? How can I fix it if it is even broken. Thanks!
Got it! It took me two months and the parts diagram to figure it out.
http://www.jura-parts.com/v/vspfiles/diagrams/Jura%20Impressa%20ENA%203,%20ENA%205%20Diagram.pdf
Use a water-flosser... I used like 8 full water tanks and DONE.
The simpler way would be to try to point up the water-flosser through each of the four holes of each spout... It will be a mess but it should work.
The other way:
1.- Take the grey plastic panel out from the front dispenser. Use a small flat screw-driver, start from the top, there are 2 clips, and then 2 other clips on the bottom.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-0.jpg ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-2.jpg 2.- You will see the dispenser "inside", a two black tubes with the spouts at the end and an air intake (I guess) on top. Take out the air intake, that will let you have access into the tubes with the water-flosser.
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-9.jpg 3.- Take your time "flossing" your dispenser, as I said it took me like 8 water tanks... a lot of coffee residual got accumulated (to my surprise).
ena-3-troubleshooting-right-now-appears-nddfxdzj3csnr0xni24gr4jm-4-14.jpg 4.- Voila!
Jan 29, 2011 | Jura Capresso Jura Ena 3 Espresso Machine ...
Jura Capresso Jura Ena 5 2Cup Coffee Maker Logo
316 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
