Question about Amana ABB1927DE Bottom Freezer Refrigerator
Bad smell from motor
I started to smell a fowl ordor coming from the fridge. I cleaned out my fridge and found something leaked down to the bottom. Some of the liquid went in the slots in the back bottom of the fridge. Today the smell is so worse. I pulled out the fridge. The smell is coming from the vent on the bottom where the motor is. Water tubes are connected to the base so I'm afraid to remove the back panel. Is there anything I can do?
    President:
  • 1,099 Answers
You need to remove any spoiled food from the refrigerator and clean the interiors with hot water added with baking soda. You need to clean the door seals and remove the breaker strips. Also check for unusual wet insulation.
Hope this work
Posted on Jul 28, 2010
SOURCE:
How do I get rid of this terrible fishy smell from my freezer/refrigerator?
Hello Heather.
Have you had anything wrong with fridge that caused the smell.
Try charcoal in both fridge and freezer.
Hope it will help.
Fish smell is hard to get read off
May 21, 2015 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My Freezer-Fridge has a terrible smell, almost smells rotton or like something died. What would cause that smell?
It could be mold, clean with clorox and then wipe down with baking soda. Make sure you check your rubber rims/seals.
Dec 11, 2017 | Refrigerators
Freon leak in refrigerator?
no refrigerant leaks have little to no odor and if it was leaking bad enough to smell it the unit would be out of refrigerant and not cooling...the problem sounds like gases coming off of a veggie of something un-covered inside the fridge--have you put any veggies in the fridge or freezer un-covered check real good if one or a piece of something has fallen behind something else where you cannot see...all else fails remove all your products from the unit and clean and get a box of odor control arm&hammer to rid the smell..as for a leak in the sealed system i think your just fine.
Mar 27, 2012 | Samsung RF265AA Bottom Freezer French Door...
There is a bad smell that I get a wiff of when I walk by. The smell is on the right hand side of the frig. Sometimes it can be smelled for a short distance. The smell is not coming from inside the frig,...
Some of them do have a drip pan under them ,at the bottom of the frig there is a cover that will come off may be screwed on may snap off when you pull on it.Take a flashlight and shine under it after you get plate off you should see it .You can put a cap full of bleach in it should take care of your problem.
Sep 20, 2017 | Whirlpool GX5FHTXT Bottom Freezer French...
My 2 month old Amana Refridgerator with Freezer on
If your sure about spoiled food. Spoiled lemons are one of the worst, and the machine has not been abused, it's a problem of the selling dealer. Fan motors have been known to create an odor when their windings start to burn. Plastic items that become detached from the interior cabinet and wind up laying on the defrost heater which gets very hot during defrost is another, however, I would demand a service call (free) since everything on it is under warranty. Make sure it's creating the odor when the tech shows up.
Oct 30, 2009 | Maytag MFD2561HE Bottom Freezer French...
Terrible odor from bottom front of fridge
The milk probably is gone, but there may be something in your coils. Inspect from front at the bottom, behind toe kick trim or from the back by removeing the access panel on the lower back of the frig. Coil cleaning should be done with the frig unplugged, vacuum out the dust and with a small brush resembling a bottle brush but smaller. clean between the coils. Don't force the brush. Twisting with light pressure will work just fine.
Jul 09, 2009 | Refrigerators
Ammonia smell coming from fridge, can it be repaired?
Yes, it's fixable. The refrigerant is leaking. Leak would be found, repaired, system recharged.
May 27, 2009 | Electrolux Refrigerators
Whirlpool side by side, clicking noise, strange smell from bottom
The clicking is from your compressor relay on the side of the compressor it has eather went bad or a condenser fan motor is not running this will cause the walls to be warm if the fan is running in the back try cleaning the coils hope this helps
Mar 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fan blows out a smell from underneath fridge could it be leaking gas.
call the repairman back and say forget it ,on the motor youll see a flat pan ,like a cookie sheet on top ,the excess water from the freezer drains into a tube and into that pan as the motor gets hot it evaporates the water,just clean the pan,shut down fridge,unplug and let motor cool,clean the pan and tell hubby not to waste good beer lol
Apr 30, 2008 | Frigidaire FRT18B4A Top Freezer...
Kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Nov 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
377 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Carmen Mikulic
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
