Question about Averatec 5110H Notebook
Laptop won't stay on. Tries to power up, then shuts down. Currently does not have a battery; I use adapter.
  • 358 Answers
This is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again.
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself), and try to clean, or better still replace your processor fan.
Also clean the air-vent where air is supposed to enter the laptop
If you cant do it by yourself, you can easily get a technician to do it for you.
Also, remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
I have actually had the same case before, and after doing what I've just told you, it stopped behaving like that.
Then always make sure that your laptop is in a well ventilated, cool environment and that the environment is free from dusts.
Kindly let me known how it goes after you've tried this.
Hope this helps you out.
Posted on Jul 29, 2010
Acer aspire 4736g shut down unexpectedly
try using a cooler pad for your laptop for heating issue,
try changing the RAM also sometimes the faulty RAM also does this
Jan 17, 2013 | Computers & Internet
Battery won't hold charge
It most likely needs a new battery, but you could try giving the battery a full charge first:
1. Power off the laptop and disconnect the power adapter.
2. Re-seat the battery (remove/reinsert)
3. Reconnect the power adapter and let it charge overnight. (6 hr+)
4. Disconnect the power adapter.
5. Power on the laptop (run under battery power only)
If it doesn't boot up and shuts down immediately, it's probably time to see about a replacement battery.
2.
Jan 11, 2013 | Samsung Q430 Laptop
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Screen stays on Dell opening screen on XPS 1640
Take battery out and let the power drain-out for 30-mins.
After that, (with the battery still out,) plug-in the AC-adapter/charger and try to power it on.
If all is good, then when you get a break, you can shut it down normally and re-install the battery.
Aug 21, 2012 | Dell Studio XPS 1640 Notebook
My Acer Extensa 5635z,is shut down it self in few minutes when i start it up..
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 19, 2012 | Computers & Internet
My laptop was left with the top down and turned on. It was plugged in and when I opened it to use it again, the screen remained black. I tried using different keys but nothing would happen. I unplugged...
Hi, Nan.
Disconnect the power adapter, flip the laptop, unlock and remove the battery. Then, reinsert and lock the battery, connect the power adapter and try again.
Hope this helps.
Jul 30, 2011 | Toshiba Computers & Internet
My acer laptop will not stay on. It tries to power up and then turns off. It repeats this over and over.
Try taking the battery out.
unplug the power adapter, and replug the power adapter but leave the battery out.
Turn on the laptop, if it powers on plug the battery back in while it's on.
If it doesn't then it could be something with the power adapter or maybe the port is loose on the laptop that it's not charging the battery.
Mar 08, 2011 | Acer Computers & Internet
I have HP 6000 series Laptop although the blue power indicator is light is on the laptop will not charge the battery NOR provide power to run the laptop. upon start up it tries to come on then shuts...
take out the dvd drive and the hard drive. Then hook up the ac adapter and see if the laptop stays on when you push the power button. Take the memory out and see if the laptop stays on, if it does then that means one of the memory sticks is bad.
After you do all of these steps if you can't get the laptop to stay on then the motherboard is bad and would need to be replaced.
Jan 27, 2010 | HP Pavilion dv4000 Notebook
My laptop shut down and wont start up anymore.it tries to start up. i brought a new battery,but that doesn't seem to be the problem.it still wont start up.the blue light button that you use to start it...
The new battery stays on the shelves for quite some time and probably discharged. Does you ac adaptor work? Make sure it does, charge it up first a bit then start it. If you have voltmeter, you can measure its output which should be around 19 volts. Sometimes the connection to the laptop also gets loose after a while, but make sure the ac adapter has power to it.
Aug 12, 2009 | Computers & Internet
Averatec 5110H Notebook Logo
43 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
