Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
Where is the power steering filter on Ford 3000 tractor
2 Suggested Answers
  • 13 Answers
SOURCE: Hello, I need to remove the steering wheel on my
Hi AD, I had the same dramas with my 3600. I had a steering wheel puller but found nowhere inside the wheel to put any bolts in, so I used 3 "D" shackles and short chains around the steering wheel spokes to the puller hub, added LOTS of WD40 then wound the puller breaker bolt in until the spokes started to bend with tension. (Sounds pretty rough but I had no other option). Everyone I asked about the procedure insisted that there were bolt holes in the hub of the steering wheel for the puller but in our instances, there are none. I also used a piece of hardwood with a fork cut in it to fit around the steering shaft (removed the trafficator arm first) then bashed it upwards with a mallet until it came free. IMPORTANT NOTE> leave the steering shaft centre nut on the end of the thread to avoid having the steering wheel smack you in the chops when the wheel comes free. Best of luck,
Errol
Posted on Apr 10, 2010
Ford 3000 tractor steering difficult to turn
lots of moving parts to wear
steering box ?
Nov 05, 2016 | Ford Garden
Ford 3000 tractor steering issue
lots or parts to wear out or stick
1993 ford tractor 3930. How do I remove power steering pump to change filter?
extremely hot power steering pumps indicate pump under extreme pressure all the time and high pressure oil movement
could be faulty pressure relief valve in the pump
as to removal of the pump disconnect the oil lines and remove ant mounting bolts
for specifics then talk with a ford tractor service center
Aug 29, 2015 | Ford Cars & Trucks
WHERE DO I ADD HYDROLUIC FLUID IN A FORD 30000 Tractor
On the floor pan next to the gear shiftier you will see a raised
BOLT, unscrew and you will find a screen filter inside, take filter out and clean with diesel fuel, replace filter. You can add the hydraulic
fluid there as well. NOTE: Purchase a owners manual on ebay they are important to have, and will more than pay themselves.
Feb 18, 2015 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Power steering fluid coming up steer colume and leaking out on a ford 2000 tractor
Remove steering wheel, throttle cable and cowl . unbolt the top portion (4 bolts)of steering housing to expose shaft (DO NOT REMOVE THE STEERING BLOCK IT'S THE PIECE WHERE THE P/S LINES CONNECT) .Buy a top portion steering kit with seal and o rings replace them and button it up, Test for any leaks, if good you can replace the cowlect. It is a easy fix, the hard part is removing the steering wheeland cowl.
Oct 29, 2012 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Where do you find the hydrauclic oil filter on ford 2000 tractor it not external
Hydraculic filter is located in reservoir under seat, same oil for rear diff and hydrauclic system. Metal mesh inlet filter at end of return pipe.
Dec 10, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Hello, I need to remove the steering wheel on my Ford 3000 tractor.It seems rather stuck after 40 years.Are there any threads inside it or is it suppose to be pulled straight off? regards AD
Errol
Mar 29, 2010 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Hard steering 4000 ford 1964
you can fine the parts at Salem tractor supply in Salem NY they specialize in old tractor parts
www.salemfarmsupply.com/
Jun 26, 2009 | RTO Ford Tractor 2000 3000 4000 5000 Water...
Open Questions:
See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
309 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
