Question about Kenmore Dryers
Clothes are not drying yet they are hot. Wondering what could be wrong. Model #11072812100
    Brigadier General:
  • 4,088 Answers
Vacuum out all air vent spaces and hoses including the outside grill. Wash the lint filter in hot water and detergent to remove the fabric softener deposits which block air flow. Hope this helps!
Posted on Jul 28, 2010
FGR231ASY GAS DRYER BURNS FLEESE MATERIAL CLOTHING WHY
Hello my name is George,
I was wondering if the dryer was just burning fleece or all of your clothes. Fleece is a very delicate material, and should be dried on low temp or delicate depending on your drier. Driers are thermally protected inside with various parts. If the drier is getting to hot one of these would have caused the drier to stop heating. If the drier is burning all the clothes and not just the fleece I would recommend having a technician come out and check it as this could be a hazard for you and your family.
Oct 26, 2012 | Dryers
The dryer gets hot and then cuts off now it want even turn on I was wondering if it was the therma fuse, thermostat and the heat element that went wrong. E-mail address is mrcal32@hotmail.com
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 26, 2011 | Maytag PYE2300AY Electric Dryer
I have a Whirlpool commercial dryer model number LEQ7030KQ1. I will wash a load a clothes in the wash machine and they will come out so they are as spun dry as they can get. The problem I experience is...
Did you mean that you need to press manually to have the drying done well, if so the program settings is what is wrong?
Does a good timing setting work on the set?
Please clarify more.the fault you are.experiencing.
Sep 28, 2010 | Whirlpool LEQ7030KQ Electric Dryer
Not blowing hot air to make the clothes dry. What's wrong.?
I dont know the make or model but firstly is the drum turning if not then check the drive belt.If ok then it could be the safety thermostats or the heater thats faulty.
Hope this helped.
May 10, 2010 | Dryers
Kenmore dryer hot, but doesn't dry clothes...also spueaks
Sam,
A dryer function is really simple:
Gets hot, boils left over moisture from clothes and it needs to blow it out.
If it is getting hot and it is turning - Then your problem is in the exhaust system.
Check all pipes that carry moisture/steam/vapor out of your machine and make sure is free of any restrictions.
Good Luck
Aug 18, 2009 | Roper RES7646KQ Electric Dryer
Model FDE336RES1. Is drying very hot only. Even
sounds like your hi-limit switch (contacts welded themselves)if its as hot as you say it is and wont shut off heat.or the clothes setting temp sensor is faulty
Jul 29, 2009 | Dryers
I have a Kenmore gas dryer 90 seriers, and when I dry clothes it will only get hot for about min, than stays warm durning the period of the drying cycle, what is wrong and how do I fix it....
The problem is with the gas assembly coils. They get hot and quit. Then later on they cool off and will work a little bit. Making it an agrevating intermittant problem. These are only 20 bucks and easy to replace:c433b30.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 22, 2008 | Dryers
Dryer doesn't dry
no but are you sure your replacement parts are correct the cycle stat is usally running about 140 - 160 temps did you switch the high one and the cycling wires or parts?
May 12, 2008 | Dryers
Clothes not getting dry
umplug your vent and run dryer see if that will make a different when dryer your clothe if not may be gas coils
Mar 30, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
