Question about Sharp AR-M205 Copier
H4 display as the copier is powered on whart should i do
    President:
  • 2,072 Answers
You press # * C * . that will enter the machine into diagnostics.
Then enter the number 14, as if you were making 14 copies. Then I believe you enter 1 and press start. The machine will reset and come back to ready.
Posted on Aug 02, 2010
What does Olivetti d-copia 120 error message H4 mean?
  1. H4 00 means Heat roller abnormally low temperature
Jan 26, 2013 | Office Equipment & Supplies
H4 Displays
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
The copier displays H4 What is the solution?
Jan 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-800 is blinking H and 4 what could be the problem?
the error code H4, means that an abnormal temperature was detected in the fusing section (the hot roller was not working properly during the initialisation of the printer), to solve the problem;
  1. unplug the printer from the power source
  2. wait for 10 mn
  3. plug the printer again to the power source
  4. switch on the printer
if the error H4 still displayed, you need change the fixing unit, that must be doing by a qualified technician,
Dec 14, 2010 | Sharp AL 800 Copier
Display panel h4 code any clues?
This error is displayed when the Fixing heater has not reached normal operating temperature after a specified time.
It is usually a blown heater element.
You will need a technician to repair this.
May 01, 2010 | Sharp AR-235 Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Dec 17, 2008 | Sharp SF 2020 Copier
Please Help
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
H4 Problem
Hi there, if you want to clear this code its very simple, do the following: -on your control panel locate the clear and auto exposure buttons, next -hit in the following sequence clear, auto, clear, auto without holding them down, after that all your panel lights should go out. If they do not you have to keep trying...They will go out. -Next program the machine as if your going to make 14 copies -Once 14 is displayed, hit the green start button and your copier should be working again. Cheers! :)
Sep 11, 2006 | Xerox WorkCentre XE88 Laser Printer
Sharp AR-M205 Copier Logo
41 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
