Question about Kenmore 490 sq. in. Cooking Area Gas Grill 15227
One burner out of four ignites when trying to ignite another everything shuts off
3 Suggested Answers
SOURCE: Kenmore Gas Range - 2 knobs don't activate ignitor
there is a switch that is broken behind the knobs they cost no more than $15.00. remove the knob so that you can see it it's white in color.
Posted on Dec 10, 2008
heatman101
  • 43501 Answers
SOURCE: Kenmore elite dual fuel range - all burners'
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 07, 2010
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
When one burner knob is turned to ignite all four burners turn on.
What do you mean by "all four burners turn on"
Some electronic ignite systems turn on on all the burners, But just the SPARK not the gas part of the burner.
Is this what you are describing?.
Jan 11, 2011 | Jenn-Air JGD8130 Gas Cooktop
The igniter on the left front burner of the
YOU HAVE a shorted ign sw. some of these only came in a wire harnes of 4 . and if they don't change all four when in there .. mm hope this helped .. feed back pls ..
Jul 20, 2010 | Amana AKS3040 Gas Cooktop
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
The igniter glows and the burner starts but shuts down after abou
one of two things it could be the flame sensor or the control board for the entire unit
Oct 02, 2009 | Goodman GMS90703BXA Heater
After starting my GE gas dryer , the burner fires and everything seems fine . The burner stays on for a few minutes and shuts off like it's supposed to . After a few minutes , the glow element turns on to...
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 01, 2009 | Dryers
GE XL44 range - electric igniter for top burners not working.
Sounds like igniter problem. Did some one pull the electrical cord or has a fuse or breaker blown/ Things to check. Your igniter is run by electricity.
Dec 30, 2017 | GE Profile JGP636 Gas Cooktop
Burner doesn't ignite every time
Clean the ignition insulators of any spilled food residue and inspect the burners for any clogged orifices. That's my general solution for this type of problem. I can't give you more specifics because I don't have a service manual for this one but that. If your documentation has specific burner cleaning instructions follow that to the letter.
Jan 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Igniter will not turn off once burners are lit.
I've had the same problem for 2 years. Today I removed the four burner tops, the 15/16 inch bolt that holds the burners in place, took everything apart (simple connections underneath), completely cleaned and dried eveything. I also cleaned the 4 knobs and making sure the 4 swiches slide up and down freely then dried everything with a hairdryer. Is now works fine but if the problem comes back, I'll simply unplug the cooktop and light it manually. P.S. I stripped one of the large 5/16 inch bolt that had become weak and brittle. - Try using water or some liquid to loosen the bolts as necessary. Good luck, CHEERS!
Oct 13, 2007 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Kenmore 490 sq. in. Cooking Area Gas Grill 15227 Logo
22 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
