Question about Dometic RM2652 Refrigerator
Rm2652RB refrigerator stopped cooling
We have a rm2652RB refrigerator and it has been working fine for the past 4 days then it just stopped staying cold. the freezer is slightly cool. the trailer has a 1/2 bubble off level (side to side). everything appears to be running normally either on gas or AC power.
  • 24 Answers
I would say first test the thermistor at the back of the fridge on the lower circuit board,the other solution pertains to household units.....???
Posted on Aug 10, 2010
    President:
  • 1,099 Answers
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 – Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Good luck......
Posted on Jul 28, 2010
Fridge is not staying cool after defrost--only stays cool for a couple of days then stops cooling until we defrost again
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Danby Propane Refrig-- Low Cooling Output
good day,
hope this link below will solve your problem.
ref
Aug 12, 2009 | Danby DPR2262 Top Freezer Refrigerator
Refrigerator/Freezer Whirlpool ED25TE stops working
Check to see if the Finn type coil next to compressor is dirty and clean it out with a brush or vacuum
May 19, 2017 | Refrigerators
Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Mar 17, 2008 | Maytag MZD2766GES Side by Side...
Dometic RM2652 Refrigerator Logo
409 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
