Question about Fujitsu Heating & Cooling
FUJITSU AST17RSA-W. Motor stays on when I turn it off.
The unit is a Fujitsu AST17RSA-W split system installed in 1997. When I turn the unit off with the remote control, the unit appears to turn off, and the heating stops, but the compressor motor keeps running. I can hear it whirring softly. When I came home yesterday the bottom vent was covered in water drops. This was after it was run on heating in the morning for a few hours. I had to turn it off at the wall to stop the motor running, and then the unit gave a big "sigh". Is there a way to reset the unit myself? Thanks.
    Loyalty:
    Visited the website for 30 consecutive days.
  • 492 Answers
Make sure you are not just turning off the fan even though indoor fan is off when temperature is not met compressor will still run thinking unit is still calling .
Since it's a old system it might wire differently for newer model .If there is also a wall thermostat for this unit try shutting it off from wall thermostat and see what happens.
That sigh sound is the reversing valve so that's normal.
Posted on Jan 05, 2018
    Scholar:
    New Friend:
  • 149 Answers
Sounds like the contactor/relay for the compressor is stuck closed. I haven't got a circuit diagram but if you're lucky you may be able to just change the relay. If it's part of an integrated circuit board you will probably be out of luck as this is a very old model and I doubt that many parts are available.
  • 86 Answers
SOURCE: Supplier of Wireless Remote for Fujitsu Split Air Conditioner
why want to replace remote.no idea abt w.canada
Posted on Mar 17, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
  • 334 Answers
SOURCE: drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Posted on Jun 28, 2009
  • 81 Answers
SOURCE: fujitsu asya09lcc wallmount split lights flashing indoors
According to the service manual page 8, the unit has an 'indoor unit control error'. Below is the link to the manual. Hope this helps. http://www.oceanairdist.co.uk/assets/pdf/service/Fujitsu/ASYA09LC.pdf
Mat
Posted on Jul 16, 2009
SOURCE: My Fujitsu Halcyon Split ac/heater wall unit is
hi i have fujistu inverter2500/600 and it is shut down after 3 minutes after starting up
Posted on Dec 19, 2010
I came across a brand new Fujitsu Split System out door unit (AOTR24JCC), so Im look for the indoor unit (ASTA24JCC) Where can I find one? Thanks
Model is over 5 years old so unlikely to get a new one. However, the outdoor units fail while the indoor is good so check eBay or your local installer.
Feb 01, 2014 | Fujitsu Heating & Cooling
Split System Error
so like a faulty component look up Fujitsu web sight for trouble shooting should have answers on there web sight
Jan 03, 2014 | Fujitsu Heating & Cooling
Have model ASTB24LDC/AOTS24LDC Inverter Fujitsu split system. As of Thursday 11th Nov, unit stopped working. Won't respond with remote. An electrician came to test it this morning, says there is power to...
I have same problem like yours to my newlyinstalled Fujitsu multi-split system (the first time use since system installed1 week ago). I rang the electrician whodid the installation; he said it must be the units themselves nothing to dowith electricity. Okay, then I rang Fujitsu and their local service agent. Theysuggested me to switch off C/B for an hour to reset the units. I followed theinstruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired tothe outdoor unit). So I used a multi-meter to test the power terminals of indoorunits (Danger! If you have no idea about this, don't even try! ): it seemed nopower supply even C/B is on. I turned to the isolator which next to the outdoorunit. The isolator was making arcing noise when I switched it on and off. Theindoor units suddenly turned on for few minutes then died again. So I figuredout the problem is that crooked isolator. I called the unhappy electricianto replace the isolator. End story....
I hope my experience will give a littlehelp to you...
Nov 13, 2010 | Fujitsu 24C1 Air Conditioner
The operation and timer lights on my Fujitsu split system are flashing on and off several times when the unit is switched off I noticed this after the system had stopped blowing air & I knew the room...
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Jul 11, 2010 | Fujitsu 24C1 Air Conditioner
Jun 01, 2009 | Fujitsu Heating & Cooling
Fujitsu heat pump noise
i would check the blades on the condenser fan motor and make sure they are not hitting anything if they are not, spin the fan see if the fan spin freely, it should, if it doesn't it could be the bearing in the motor are dry and going bad
Jan 22, 2009 | Fujitsu 24C1 Air Conditioner
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
69 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
