Question about Cameras
Action Shots are going to slow - Cameras
Actually if you are using a Powershot S5 IS. Use the TV dial mode and make sure the AF continuous is on to focus on each shot taken continuously.
Posted on Sep 08, 2008
    Problem Solver:
  • 17 Answers
Not entirely sure what you mean, but it sounds like you may need to increase your ASA setting to capture the action. If your camera allows it - push your ASA setting to 400..
I hope this helps
Posted on Apr 24, 2008
Camera seems to take a lonf\g time to recover between shots. can this be correxted by a setting? Also what setting should be used for action sport shots?
When I take a pic the speed to take another pic is slow. Takes about 3 to 5 sec's. how can I make it faster pic one after another, thanks
Dec 31, 2010 | Canon PowerShot SX130 IS Digital Camera
I took action pictures last night with the TV mode setting, ISO- 1600, with the White Balance set up. It worked fine on Saturday. I had a lot of burry shots. I am taking volleyball pictures. Do I...
What your are trying to do can be very difficult. First is with a 75-300mm lens you are going to have a hard time keeping the camea steady...I suggest a monopod. Set the camera for Action shots ISO-1600...you will need a shutter speed at least 250th of a sec. to get decent action shots.
Sep 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
What is the best setting for taking indoor action shots? My shots always turn out fuzzy and dark
There is no good solution for this. There's only a limited amount of light indoors.
First, you need the widest aperture you can get on your lens. You can get this by going to the Aperture-priority (A) mode.
Even so, you're shutter speed will most likely be too slow to freeze the action. You can combat this somewhat by raising the ISO. This will increase the noise, but I'd prefer a noisy picture to a blurry picture.
That still probably won't get you great pictures. Since you probably can't rig more floodlights in the gym, you'll be limited to using your flash if the action is taking place close enough to you (and if flash is permitted).
You can gain an additional stop or two with faster lenses, but such lenses can cost more than $2000. Unless _Sports Illustrated_ is paying for your pictures, that's probably not an option at this time.
I realize this doesn't really solve your problem. Unfortunately, as I stated up front, there is no good solution.
Jan 29, 2010 | Sony Alpha DSLR-A100 Digital Camera
Blurred pictures on action shots
For daytime, make sure the ISO is kept low, say 100, or 200 if a little dull. For nighttime or indoor, you may need to increase the ISO up to the max of 1600.
Check also the AV+/- setting isn't set too high - are the shots brighter than normal? If so, hold the AV+/- button and use the scroll wheel to bring the setting back down.
One other thing to check is your CF card - have you changed cards recently? I have two 2Gb UltraII cards from Sandisk - one is really fast, about 1-2 pictures per second, the other is really slow, about 3-4 seconds per picture. They should be the same but are not.
Also try shooting in AV mode to keep the lens wide open and get the fastest shot possible.
Hope this helps!
Mar 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Settings for dance/on stage action shots with no flash and low li
If there isn't good lighting on the stage (nevermind the auditorium), your 18-135mm lens does not have enough light-gathering ability for action shots, especially when you zoom in for that close-up of your daughter. Even at the highest ISO speed setting, you would likely have shutter speeds longer than 1/30 second, too slow to avoid camera shake and certainly too slow to freeze action. While a dreamy motion blur can make a nice impressionistic effect, I'm sure you want to recognize your daughter.
Sorry to say that the only solution for low-light, no-flash shots is to spend money on a fast lens. Either that or sneak in beforehand and put high-wattage lamps in the stage lights. The best value is the Nikon AF Nikkor 50mm f/1.8D lens available new with full warranty at B&H Photo (bhphotovideo.com) for $134.95 with free shipping. This lens gets highest marks in every professional review, and it's a huge value at that price. Or, if price is no object, go for the 50mm f/1.4D at $350. These are both prime lenses, not zoom, so you will want to get there early so you can choose your seat for the best view close to the stage.
Mar 22, 2009 | Nikon D80 Digital Camera with 18-135mm...
Shutter speed is slow
You can download the manual from
http://www.samsung.com/us/support/downloads/SAMSUNG%20S630
Mar 14, 2009 | Samsung Digimax S630 Digital Camera
Rebel xt 350d slow shutter in action mode
need to be aware of lighting conditions as well. if the lighting conditions are low then the shutter will slow to compensate
Dec 10, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Shutter Speed too slow on indoor sports for Nikon D60
Maybe. Assuming you can't add more light, you can either increase the ISO and/or open up the aperture. Try going to A (Aperture) mode and opening up the lens all the way. This will give you the fastest shutter speed possible under the conditions. That may or may not be fast enough.
Nov 02, 2008 | Nikon D40x Digital Camera
Action shots
Action shots generally require a fast shutter speed -- to freeze the motion. So you need plenty of light or a "fast" lens. A fast lens is one in which the aperture opens further to let in more of light. The smaller the number of the maximum aperture, the faster the lens, so a 28-105mm f/3.5-4.5 lens is "faster" than a 28-105mm f/4.0-5.6 lens. But usually, faster lenses cost more.
For the settings on the camera, the Rebel K2 has a Sports image mode (silhouette of a runner) on the control dial which should get you appropriate settings for most action shots.
If you want to set the shutter speed yourself use the Tv mode, and with a fixed shutter speed, the camera will set the correct aperture. Watch in the viewfinder -- if the aperture value is flashing, it means the shot will be underexposed. You will have to select a slower shutter speed.
Another way to get action shots with limited light or a "slower" lens is to use film with higher ISO/ASA. ISO 100 film is good for daylight shots, but for inside shots or evening shots, use ISO 400 film. Higher ISO film is "grainier", so enlargements will show less detail.
May 07, 2008 | Canon EOS Rebel K2 35mm SLR Camera
Action shots form my Rebel XT EOS 350D camera
Controls on the top of the EOS 350D are all found on the right side within reach of your 79a8647.jpg
Index finger or thumb.
Select sports icon on it.
Shutter speed is kept as high as possible to ensure capture of fast moving objects and action clips.
Hope its very help full to you
Oct 17, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
87 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
