Question about HP Office Equipment & Supplies
HP Laser printer model # P3005dn, has left side crumbling of paper, could be paper feeder
  • 52 Answers
If print quality is affected the fuser heat sleeve torn. open back look at top fuser roller
Posted on Jul 29, 2010
Paper will not feed crumbles on right side will not feed through
Remove the sheets of paper from the feeder. Grab a flashlight ang take a look into the feeder for any debris or foreign objects that could cause this problem. If none, unplug and replug your printer into the power source to reset it. When the printer turns on, load some paper (don't overload). Try to print again. If problem continues, please don't hesitate to contact Lexmark technical support for additional assistance.
Apr 26, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How do you replace Face Down Delivery Roller?
remove the left, back and top covers.
At both ends of the shaft are plastic bushings.
Rotate them so they point in a horizontal position.
Lift the right side of the shaft(it has a white gear on the end) and then slide the shaft to the right to release the left side from the chassis.
Feb 02, 2010 | HP Laser Jet Printer P3005dn
Even if there is nothing to print on the other side the machine pulls the paper back in for duplexing
To prevent this you would have to set printer for single sided printing. This is an automatic feature in hp printers mine does the same thing.
Sep 29, 2009 | HP Laser Jet Printer P3005dn
Samsung Laser Paper Jam
could be obstruction in paper path or fuser damaged
Jun 21, 2009 | Canon imageCLASS D680 Laser Printer
SCX 4521F multi/f keeps reporting "Document Jam"
Hello there,
If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Feb 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Saying paper jam dcp-135c brother printer
 Hello there,If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Ensure that:
Jan 30, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Hp 6110 all in one
This problem doesn't seem to be exclusively a 6110 problem. HP.com has a web page that addresses this and related issues:
Paper Catches Causing Paper Jam
Post back your results. Good luck.
Oct 14, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
mukhtar21 shaikh
mukhtar21 shaikh
