Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Whou ever !!!
Ok first is green lite and is no picture onley the sound . after 1 min the tTv is gooing off and the red light for the lamp is on. i change the lamp for the new on and i chack the smoll power board by the lamp. i dont know what is the correct voltage but it luck ok. i clenet out.
cant localizate the problem ...... hellp
  • 31 Answers
First pull the lamp and make sure the lamp is ok. lamp is bad if shattered or black/white spots at bottom of the lamp. if the lamp is bad get another one from mits and only mits just only oem lamps
Posted on Apr 24, 2008
  • Mitsubishi Master
  • 8,617 Answers
That chassis has bad capacitors. two 1000uf capacitors on the PWB can cause the problem your describing but I wouldnt attempt the repair without the manual as the chassis is hard to remove, the manual makes it easier. you can get the manual at this link and they will give you free tech support as well.
http://servicemanuals.vstore.ca/
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Lamp went out & replaced it but no picture. Sound comes on!!!
you have a safty switch open most likely on the door you took off to replace lamp
Feb 03, 2010 | Toshiba 62HM95 62" DLP HDTV
Hitachi Ultravision 50in will power on but no picture or sound!!!
Replace Ballast Board it is what turns Lamp on! Call Encompass for Part 1-800-638-3328
Sep 26, 2009 | HP Pavilion MD5020N 50" DLP HDTV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-43LC14
The TV shutdown error code can help you with this problem. If the power led flashes green for 2 Min's then red. The Lamp led should flash red 1-2-3 or 4 time every 5 Min's. These are error codes that may point you in the right direction to you problem.
May 24, 2009 | Panasonic PT-43LC14 Television
Tv turns on and than red status light comes on and shuts down
it sounds like the 3300uf caps on the power supply have gone bad.look at them and see if they are pregnant. if so change them. while you have the shield off see if any other caps are pregnant, if so you might want to think about having the chassis repaired.
Dec 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I have a 56" rear projection panasonic tv when i turn it on green lite come on then a lamp lite comes on red no picture or sound lamp lite flashing
Doulbe check in the owner's manual, but this is usually an indication of a bad lamp or fan error. There will be a table in the owner's manual listing the error codes as shown by these lights. I can't give you more details without the exact model number.
hope this helps,
Dan
Sep 08, 2008 | Televison & Video
Rear projection tv picture problem
Sounds like a tuner or Video output problem. What make and model set do you have.
Jan 09, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
