Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
HLR4266WX/XAA this is an PU02 L6 chassis. We replaced the color wheel now color is bad, lots of blue, red is brown, etc. Any suggestions?
  • ambsador Jul 29, 2010
    I am just wondering has anyone changed the color wheel in this model and if so was there a jumper?
  • ambsador Jul 30, 2010
    HLR4266WX/XAA this is a PU02 L6 chassis. We replaced the color wheel now color is bad, lots of blue, red is brown, etc. Any suggestions?
    Has anyone changed this colorwheel on this model and is there a jumper in this set as explained in this link?http://www.jangro.com/electronics/dlp-tv...
  • 4,889 Answers
Ok.. Do you hear any whirring noise(just ensuring that you installed it correctly).
Posted on Aug 03, 2010
  • 712 Answers
Check if the color wheel that you have purchased is an original product of Samsung (The company to which your unit belong). Also check if something has gone wrong with it by asking a nearby t.v expert to check it. You may be well inside the warranty period to ask for a replacement.
Best Regards. Thank You.
Posted on Jul 30, 2010
  • ambsador Aug 02, 2010
    Has anyone changed the color wheel in this model before and is there a jumper that needs to be removed? I have a link in the previous posts illustrating this but it is another model # same color wheel. Yes, it is an original part from Samsung Parts. The color wheel appears to be ok.
  • Samsung Master
  • 6,993 Answers
try to adjust the convergence on your TV, this should balance the color.
If you don't know how to adjust the convergence on your TV, follow the below procedures:
  • Select the "Menu" button on your remote control. This will bring up a display menu on the screen, giving you access to all of the customizable settings on your TV.
  • Select "Settings" from the list of available menu options. This will bring up a variety of different settings categories, including "Color" and "Channels."
  • Select "Convergence" from the list of menu options. This will bring up the settings to adjust the convergence on your Apex Rear Projection TV.
  • Use the arrow buttons on your remote control to line up the colors that have appeared. If your convergence is out of sync, you will see three lines of color. They should all be overlapping as one solid line. When you are finished, press the "Menu" button on your remote control to exit the menu and continue watching television.
Good luck.
Posted on Jul 29, 2010
    This is not an Apex TV it is a DLP and does not have convergence settings. HLR4266WX/XAA this is an PU02 L6 chassis. We replaced the color wheel now color is bad, lots of blue, red is brown, etc. Any suggestions?
  • 10,594 Answers
After color wheel replacement, there is adjustment requires, it calls Index Delay Adjustment. I would recommend to have service manual cop in hand as procedure is written in service manual, however, below is brief procedure about index delay adjustment to correct color phase/ color wheel timing to have correct colors.
1. Turn off the power to put the unit into the STAND-BY mode.
2. In order to enter the Service Mode, Press "Mute" → "1" → "8" → "2" → "POWER" buttons on the Remote Control.
3. Select "Service" on the first display of the Service mode menu.
4. Press the ▲ ▼ (Up or Down) button to move to INDEX DELAY, then press ENTER to select.
5. The INDEX DELAY setup screen (with a red bar at the bottom of the screen) will be displayed.
6. Press the ◀▶ (Left of Right) buttons to adjust. Check the red color at the bottom of the screen at its minimum and maximum
values of changing from red to magenta, then adjust to the mean value.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Jul 28, 2010
  • 8 more comments
  • ambsador Jul 28, 2010
    did that already
    We already did this adjustment and it did no good. We also looked at the CCA adjustments no help. Under the actuator gain adjustment the red and blue plus signs were backward and no amount of adjustment made a difference. Does this model have a jumper that needs to be removed?
  • Shahid Electronics
    Shahid Electronics Jul 28, 2010
    OK, then there is another adjustment calls CAA (Color Coordinate Adjustment).
    CCA equipment(CA210) is required to perform that adjustment and Samsung service center has that interface.
    Check any jumper settings on color wheel circuit board and change it to achieve correct phase color.
    I almost said same thing that you posted. Jumper setting can be observed on old color wheel, if you have it.
    Please explain about jumper settings. Does this model have the jumper that needs to be removed to correct this problem. We have seen other posts about this jumper, (white cap), needing to be removed to solve this problem. The only thing it is not for this model #, it is for the same color wheel though.
    As I explained in previous post, observe old color wheel, jumper is inside opening, inside a vertical metal plate about 1 inch under
    sticker.it is black rubber remove it on new color wheel if it was removed from old/ defective color wheel to fix the color phase problem.
    When I said cap I did not mean a capacitor, what I have seen on other websites was a post about a white plastic cap on two posts that need to be removed to correct problem.
    Are we talking about the same color wheel? This old color wheel has no jumper and the posts i am talking about show the jumper being inside a little square hole inside the set. The following link is for the post I am talking about.
    Yes, it seems we are talking about different color wheels. OK, remove white plastic jumper as advised in given thread and see its results and if that does not fix the issue then put it back and confirm that replacement color wheel is exact same as older one.
    Shahid Electronics Jul 29, 2010
    ok, no problem.
Border shadow on left side of samsung
you will need the light tunnel replaced, 1 or more mirrors in it have come unglued. That part# BP96-01961A $52.05 at this website:
http://www.samsungparts.com/Products/Parts_and_Accessories/HLR4266WX/XAA/Default.aspx
Mar 05, 2015 | Samsung Televison & Video
Samsung HLR5078 50" tv - replaced a shattered color wheel but the colors are way off with the new one - yellow in place of both red and greens.
I'm not sure you received the correct color wheel. Do you have anything left of the shattered color wheel to compare it to the new one? Seems if you got the correct wheel then the colors should of been the same. Color wheels spin at the same rate of 60Hz. The only reason why you would get the wrong color is that the color on the wheel is in the wrong placed at the right time. I would see if you can get a wheel the same # as your original one.
Nov 11, 2014 | Samsung Bp96-01103a Dlp Tv Color Wheel L6...
I cut the plugs from the facturay harness for the radio now i am trying to hook everything back up and do not now what colors from the harness goes to the stero. then what the other colors go to that are...
Here are the stereo wiring colors.
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Jan 16, 2011 | 1997 Nissan Maxima
After color wheel replacement colors are wrong
you need to index the color wheel after repalcing it so its spinning at the correct speed
Apr 30, 2009 | Televison & Video
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
How do I know if it is L6 or L3 chassis
you need to look on the right side of the set (facing the front of the set) for a small label that says
model code...
serial number..
version..
if the version number is blank or PW01 you have the
L3 chassis.
if it says PU02 then you have the L620 chassis
also the L3 chassis has the ballast on a slight angle and the L620 has the ballast straight.
Dec 29, 2008 | Televison & Video
HLP 4663WX/XAA
sounds like the color wheel has gone out
Dec 17, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Prints all yellow, with some blue and black, no brown
the problem is very simple the magenta ink the cartridge is over or the head is been blocked from where the magenta ink comes out,
because red colour requires ---yellow plus magenta(pink)----to make it red.and ----dark yellow plus magenta(pink) -------- for brown colour.
Nov 22, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Speaker wiring for a 1993 dodge dakota
To my knowledge a 1993 Dodge Dakota would have the below wiring arrangements for its stereo/head unit:
Constant 12V+ Red/Blue
Ground Chassis
Illumination Black/Yellow
Dimmer Orange
Left Front (-) Blue/Orange
Right Front (+) Purple/White
Right Front (-) Brown/Blue
Left Rear (-) Brown/Red
Right Rear (+) Blue/White
Right Rear (-) Blue/Red
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Car Audio & Video
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
494 people viewed this question
Jerry Greenberg
Jerry Greenberg
