Question about Kenmore 57029 Side by Side Refrigerator
Water dripped on bottom of fridge
    President:
  • 1,099 Answers
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Think this will solve the problem....
Posted on Jul 28, 2010
I have mold! in the drain on bottom of fridge i assume because of the water dripping down the walls all the time?
Try to put a tray under the fridge to collect the dripping before handling the mold.
Dec 07, 2015 | Liebherr Refrigerators
Eaton's Viking Model 1266F fridge leaking defrost water
Your idea/plan sounds pretty good. There is a drip pan under the fridge right? it might be a good idea to run it into that. Good luck!
Jul 26, 2014 | Viking Refrigerators
Water is dripping from the bottom of the fridge (slow drip). How do I fix it. I have a Maytag French Door stainless steel fridge (4-year-old) with freezer on the bottom.
There should be a drip tray catching the defrost water... it may be overfull... Try to remove it and empty it. The tray is actually supposed to have a heat evaporator to dry up the water before it overflows. Your may be fuller due to excessive frost also... from hot temperatures outside or opening the fridge too often or for too long... good luck!
Jul 24, 2011 | Freezers
Water dripping onto back of shelves and into drawers and bottom of "designer style" frig
There is a tube at the back of most fridges which routes freezer water to a evaporator tray at the bottom.
Usually in the fridge at the top just below the freezer is a small collection cup. If that cup or tube is blocked then it will drip water into your fridge.
Let me know if that helps.
Dec 06, 2009 | Whirlpool Refrigerators
Trickling water noise coming from the bottom of the fridge.
It may be nothing to be concerned about. The water produced during the defrost cycle drains into a pan at the bottom of the refrigerator. This water is then evaporated by heat from the refrigerant coils.
You may be hearing this water dripping into the pan from the tubing that carries it from the inside of the refrigerator.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frezzer leaks into fridge
This is usual. In some refrigerators it is designed that way. It will keep the vegetables etc. in the fridge from drying out. Usually this spout is close to the back wall of the fridge. It is designed such that water drips directly to a small hall on the bottom of the fridge. It is important that you don't push the dishes or food in the fridge too far back. Otherwise water will be on you food. This spout should be far back as I mentioned. If, for some reason the water is dripping not close to the back, the spout may have beent damaged or bent. Check to see whether it is OK.
Jul 31, 2009 | Refrigerators
Water drips from bottom of fridge. It happens
look in the bottom of the inside of the freezer, you probably will see ice buildup.You have to clear the drain which is stopped up at the bottom of the panel that covers the freezer evaporator.Every 8 hours the drain receives water from the auto defrost and needs to go in the drain, if drain is stopped up it freezes and eventually runs out the front
Mar 25, 2009 | Hotpoint HSS25GFP Side by Side...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Hot coil?
Hello gaylekell,
Welcome to Fix ya
You said, you just opened your fridge a minute ago and it sounded like water or something is dripping on a hot coil at the bottom back of fridge.
It is in the auto defrost mode!
All frost free or self defrost refrigerators use this method of dispersing the water into the air as vapor.
As the water accumulates below the fridge is supposed to blow the water onto the hot coil or compressor and evaporate it away. That's why there are no more drip pans to empty!
If you do not notice any problem in the operation of your fridge
and it is not excessively loud, (Which I do not think it will be under a normal situation )
Your fridge is more than likely running normally and fine!
How old is the fridge and what's the model number?
Thank You for utilizing my advice, Huuum
Please remember to leave a rating!
Oct 03, 2008 | Danby Designer DAR1102W Refrigerator
Kenmore 57029 Side by Side Refrigerator Logo
154 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
