Question about Frigidaire Kitchen Ranges
Cooktop lockout remains on - Frigidaire Kitchen Ranges
Will be glas to tell you how I did it for the same price offer you made to me.
Posted on Apr 25, 2008
Error 40 on kenmore convection oven
The 40 error code indicates a failure of the cooktop lockout board. The cooktop lockout board is not communicating with the main EOC electronic oven control. This could be a loose wiring harness or either the EOC board or cooktop lockout board is faulty. This type of diagnosis will require using a volt/ohm meter. If you decide to check the harness to the boards you will need to remove the back panel for access.
Oct 15, 2017 | Kenmore Ovens
How can I get self clean to start?
To Self-Clean Using AUTO-CLEAN
1. Press AUTO CLEAN.
2. Press the HOUR and MIN "up" or "down" arrow pads to set the desired self-clean cycle time.
3. Press START. The oven door will automatically lock. "CLn," "LOCKED," "ON," "CLEAN," the Cooktop Lockout icon, and the time remaining will be displayed.
4. When the self-clean cycle is complete "END" will be displayed, and "PUSH"/"OFF" will blink alternately.
5. Press OFF/CANCEL. "LOCKED," "END," and the Cooktop Lockout icon will disappear from the display. "PUSH"/"OFF" will stop blinking, and clock will show the time of day.
6. Once the oven is completely cooled, remove ash with a damp cloth.
I hope this helps and thank you for a model number that made this possible for me to assist you. Good Luck
Apr 05, 2016 | Whirlpool GS563LXSS - stainless Steel Gas...
Managemylife com
From the manual:
To turn the Cooktop Lockout Feature OFF:
1. Press and hold (_ until "CLO" appears (Figure 3). Continue holding
until a second beep sounds (after 3 seconds). I_1will disappear from
the display indicating the cooktop may be used normally (Figure 4).
Note: Starting a Self-Clean cycle will automatically turn ON the Cooktop
Lockout feature. The cooktop will remain locked until the Self-Clean cycle
has completed and the oven door has unlocked. If a power failure occurs
after the Cooktop Lockout has been activated, you must turn OFF the
Cooktop Lockout feature before being able to use the cooktop features
again.
Dec 14, 2013 | Stoves Kitchen Ranges
How do I fix an F40 code on a kenmore elite rlectric range model #790.46709603
The "F40" fault code indicates a Cooktop Lockout error. There is a "Lockout" control board that locks out the cooktop from operating whenever the "Clean" cycle is used. It's not normal to display "F40" unless there is a "Lockout" or an "EOC" (electronic oven control) failure. It may need one or the other or both boards replaced. If the cooktop will operate after the range has cooled and unlocked then it may need the EOC and not the Lockout board. If you can ignore the beeping and the F40 and the range will heat up again in the clean cycle and complete the clean cycle then it could have a faulty Lockout board. Here a link to a YouTube video with the instructions on how to access and replace the EOC.
Here is the lockout board if you need to order it.
Here is the EOC board if you should need it also.
All parts come with a 365 day, any part, any reason return policy.
Apr 06, 2013 | Kitchen Ranges
Electric range surface elements not working after self clean cycle.
It sounds like it is broken. You can bypass it by connecting the 2 wires together. This should be fine until you replace it. They aren't that expensive.
Mar 06, 2013 | GE Ovens
HOW TO UNLOCK JEN-AIR STOVE TOP MODEL# JED4536WR01
The All Off cooktop touch control turns off the downdraft exhaust
system and all surface cooking areas that are in use at the same
time.
The Lock cooktop control avoids unintended use of the surface
cooking areas. When the cooktop is locked out, the surface
cooking areas cannot be turned on by the cooktop touch
controls.
To Lock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds. After 4 seconds, ALL OFF/LOCK will glow red,
indicating that the cooktop controls are in the lockout position.
To Unlock Cooktop: Touch and hold the ALL OFF/LOCK keypad
for 4 seconds.
Apr 24, 2011 | Microwave Ovens
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
The burners won't work but the oven does! please help me. i was in the middle of cooking and all of the sudden it stopped working. i checked the circuit breaker box and nothing was blown. thanks! Lori
you have the cooktop lockout engaged, this may be a control failure, but try to turn off the cooktop lockout first by pressing and holding the control button with a pic of a lock by it. if this doesn't work, replace the control board.
Jul 02, 2009 | GE Spectra JBP78 Electric Kitchen Range
Our cooktop will not turn on!!
Got the same problem.
Here's a work around: Turn breaker off, second person needs to hold the CANCLE/LOCK button (keep holding it!)
Turn breaker back on and keep holding the button, lock feature may turn on, red lock light stays on, KEEP HOLDING THE BUTTON. At the end you will get a F11 (shorted keypad) warning. It may take up to 20 seconds or more but in my case the red lock light goes off, the dashes disappear and everything is back to normal.
Now here are the bad news. This does not fix the problem (I think it's the EOC). Every time the power goes off the red lock light and dashes will come back. It also may require to people to fix this/work around... but, hey, it doesn't cost anything either...
Aug 22, 2008 | Kitchen Ranges
Plug the power line press the reset button.
Jan 03, 2008 | KitchenAid 32 in. KECC508 Electric Cooktop
Kitchen Ranges Logo
121 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
