Question about Dryers
Is there a schematic for the Kenmore Elite Oasis gas dryer model no. 110.7703*, 7704*? I think a coin or something got inside and it now makes a noise when in use. I cannot for the life of me figure out how to get the layers off so I can see if something made its way inside the dryer from inside the drum.
  • tbuker13 May 02, 2008
    I figured out how to get the thing disassembled. It seems that my problem was the metal sheets glued to the outside of the drum. Not sure if they are for balance or what, needless to say it was tore up and I just removed it.
    Now when I took it apart, there was a long thin belt that was round the drum and down to a pully, I think. When I assembled the way I thought it should go, the whole thing is not very tight. Should it be tight or should there be some play in that belt?
    Thanks in advance, very helpful site.
    President:
  • Dryers Master
  • 2,651 Answers
You can remove the lower acees panel ( 3 1/4 screws across the very bottom of unit, this will give you acess, to the insideto better pinpoint where noise is coming from, also across the top of the back of the unit is 3 screws holding down the top assy, by removing this youll be able to access the screws hodling on the inner drum paddles( incase the coin(s)), has gotten between there
Posted on Apr 24, 2008
Hi, I have a Kenmore Elite dryer model 110.76962501. It was working fine earlier in the day. Now when I turn it on, it makes a humming, whirring sound. The drum is still rotating. Any suggestions?
Hi etzelmueller...
I think you have a drum roller problem or a felt seal problem on your dryer to cause the noise you describe..
Please take time to rate me.
Sep 18, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
I have a Kenmore Elite Oasis gas dryer Model # 110.77052600. The gas and electrical supplies are ok. I have no flame or glow at the burner. What are possiable causes?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
My Kenmore Elite Gas Dryer in Refresh mode the cloth comes out wet.
I think the refresh mode is a no heat tumble only setting... just to fluff your clothing...
if they were wet they will not dry on that setting...
heatman101
Aug 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Kenmore elite oasis dryer model #110.6708
not much more than a service call for 1 hour work.
Rates vary depending on location.
Expect $60-$80 plus parts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 10, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
I need the installation manual for a Kenmore Elite Oasis gas dryer. Specifically I need to know what water line attaches to the dryer (for steam), the hot or the cold?
Hello, Here's the link to view the owners manual and exploded view of the parts for your model. Once there, click on the exact model # you have (it's listed on your dryer's data plate) so you get the right one.
http://www.managemylife.com/mmh/owner_manuals/search?query=kenmore+oasis+elite+dryer+7808
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Cycle signal beeps and flashes on my Kenmore Elite Oasis Gas Dryer # 7708
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@$$%
Mar 05, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Just inherited a kenmore elite oasis dryer model 110 77092600 Where can I get a user manual? Could be online. I called Sears and they want $18 to order one!!! Kenmore charges also.
searspartsdirect.com - and enter your model #.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 22, 2009 | Kenmore Elite Oasis ST 7806 Dryer
My 18 month old kenmore elite oasis quiet pak 2 gas dryer smells as if there were a fire in it!!!!  and ironically, when i noticed the smell i also saw water around the base of the kenmore elite oasis top...
Hello plz make sure the gas burner does not have any lint build up on burner assembly inside the machine / plz clean.That usually causes a burnt smell. If there is no error codes on the display and the machines is operating fine you are chasing a ghost. If there is a pump or motor over load an error code should come up on the display.
Dec 11, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
163 people viewed this question
Top Dryers Experts
