Question about AEG Santo 3888 KG8 Bottom Freezer Refrigerator
The audio alarm was sounding this morning and the LED indicator for the fridge showed a high temperature and the freezer showed a low temperature. The freezer has since returned to -15 but the fridge is still at +14, both after activating the automatic control. Please advise.
  • isl Jul 29, 2010
    Thanks Joe, This explains why the freezer was working but not the fridge - all appears to be OK now.
  • 10,865 Answers
The actual cooling comes from the freezer and makes it's way to the fridge. Wait another 12 hours and u will be all ok again. Joe.
Posted on Jul 29, 2010
Why my fridge freezer keeps beeping four hort beeps
Temperature alarm
If the temperature becomes too warm, an alarm will sound and the temperature display will flash. The temperature the appliance is set at will determine when the alarm is triggered.
The alarm will sound and the display will flash under the following conditions:
  • - whenevertoomuchwarmairflows into the appliance, for example when food is being loaded, re-arranged, or taken out.
  • - wheneverlargeamountsoffoodare being frozen at once.
  • - whenevertherehasbeenalengthy interruption of the power supply. Door alarm
    If the appliance door is left open for longer than approx. 60 seconds, the alarm signal will sound.
Switching the alarm system ON
The alarm system is always active. It does not need to be switched on manually.
Switching the alarm OFF early
Once the set temperature has been reached in the freezer section, the alarm signal stops and the temperature display stops blinking. If the alarm signal bothers you, it can be switched off early.
^ Press the alarm off button. The alarm signal will stop. The temperature display will continue to blink until the set temperature has been reached. The display then stops blinking, and shows a steady reading. At this point, the alarm system is ready again if needed.
Aug 15, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
How do i reset a Bosch fridge freezer after switching it off
usually have to wait about 15 minutes before turning it back on otherwise the compressor will reset itself on and off till you pull the plug out for 15 minutes
Hope this helps. God Bless :O)
Apr 21, 2014 | Refrigerators
I have a 3yr old samsung fridge/freezer srl324np. this morning i woke to find the digital door display flashing, and the inside of the fridge was warm, however the interior light was still working. i've...
It sounds like a temperature sensor problem. On my RF265AABP model there is a control board located under a cover on the back of the refrigerator. There is a wiring diagram on that cover. Remove the cover if you have one, and locate the control board and power supply boards. If you have a voltmeter, check for +5V and +12V (on my model anyway) from the power supply board. If that is OK, then check the voltages on the temperature sensor wires. Mine are at the bottom of the board as shown in the photo. I have 5 temperature sensors, refrigerator (R), freezer (F), refrigerator defrost (R-DEF), freezer defrost (F-DEF), and Pantry (a temperature controlled drawer in the refrigerator). You may need to refer to your specific diagram to get the colors of wires, but it appears that the voltages should be somewhere between about 2 to 4 volts from each sensor to ground. I had a broken ice maker wire that resulted in a high reading, about 4.3 volts on the freezer sensor, so I assume high reading indicate an open sensor, and low reading indicate a shorted sensor. I am not sure where the refrigerator sensor is located. Repairing the broken wire restored the display to normal readings.
On my model the left gray wire is common, and the diagram should indicate color and a letter or so (R, F, R-DEF, F-DEF, Pantry) on my model.
Sep 12, 2013 | Samsung Refrigerators
I have a Bosch ksu 44 fridge/freezer which has stopped working - just a click,click,click from the back and the control board led's flash with each click (1.5second intervals) - is it the control...
Very common problem on that fridge and a easy fix: Replace the two big capacitors on the right side of the control PCB 1uF = 0,68uF 250V They lost their capacity causing bad uC supply and this strange LED blinking. Be aware that this blinking can be intermittent and the fridge appears to return to operation. But the uC suffer a lot of internal resets causing intermittent operation stops, low temperature and more not easy recognizable or strange mal functions. So, if You face that blinking normally the capacitors are gone. Some strange and intermittent behaviors of the fridge are also back routed to this PCB - Capacitor malfunction. So enjoy this 30min fix. The capacitors should not exceed US$2 in Your local electronic shop. If You don't want to spend the US$2 You can find the capacitors as a lucky guy in a old PC power supply.
For other more complex problems be aware that the controller board has a very nice and helpful self test option. You go in this mode holding the temperature select button of the refrigerator (not the freezer button) then switch the fridge on and stay on holding the temp button for more 10s. The self test sequence starts in the moment when You release the temp button.
LED 1: Checking sensors (Blinking=OK - Continues=NOK, something wrong)
LED 2: The Flap opens and close two times (Alarm LED shows the open and close position, so the led must go ON and OFF two times in accordance of the detected flap position from the internal reed contact. (So, no action on the Alarm LED no movement on the Flap or a defect Reed contact)
LED 3: Fan goes ON and OFF
LED 4: Drain Heater goes ON and OFF
LED 5: De- Dicer Heater goes ON and OFF
LED 6: Compressor goes ON and OFF
LED 7: End of test sequence - Initializing procedure of normal operation.
Every step takes 30s and the whole sequence take tree and a half minute. Be aware that the alarm LED is no malfunction indicator. It has only the indicator function for the sensors.
The fridge goes in the normal operation mode when he passed the sequence. No further actions necessary.
Be aware that every time when the fridge faced a total power lost he makes a short silent 30s check sequence. If he face a malfunction (Sensors or actuators) he doesn't start the compressor anyway to protect the fridge for further damage!!! So, this test sequence is a nice tool to check that the fridge is in the right conditions to start the working and even so to check the compressor function before maybe a unnecessary replacement .
With a second build in test option you can select and activate devices in the fridge. For this You hold the fast freeze button and switch the fridge on. After 10s release the button and you are in a manual test mode. With the temperature button select the component - Push the Fast freeze button to activate or deactivate. For example: Select LED6 (Compressor) with the temperature button, push the fast freeze button for ON and OFF. But I ask You to be careful on this test mode to avoid further damages. For example a blocked motor that You should release better by hand than blow up by a tricky fingertip. Enjoy this fix and feel free for Crtl C + Crtl V.
Jul 04, 2011 | Bosch KSU49630 Top Freezer Refrigerator
Alarm is going off every 2 hours indicating freezer temperature is high. We can't turn off alarm, button is not working. We have to turn off the breaker but it continues to happen every 2 hours. We...
you have a defrost or system issue open freezer drawer snow on back wall you have a defrost problem not too costly
no snow on back wall and you can hear fan running in freezer most likley a low side system leak
viking warranty on sealed system 6 years full 12 years parts
also unrelated you fridge should have hinge recall done if not done yet this repair is covered by viking
Nov 13, 2017 | Viking DFBB363 Bottom Freezer Refrigerator
After power cut the temperature of the fridge and the freezer termperature are just flashing and making a beeping noise
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
Jun 29, 2009 | Whirlpool Freezers
Why the red light blinking with audible alarm?
Your temperature alarm is going off as it has exceeded your set high temp.
Usually means you have had a power failure or you have a thermostat, starter relay, compressor or freon problem.
To find out what is happening get a therometer and put in fridge. A fridge / freezer thermometer is best but any will help
May 18, 2009 | Bosch Refrigerators
Fridge light not shutting down, alarm on, temperature heating up
you do have a switch at the top door hinge . make the phillip screw are tight at the top of the door . if they are loose the door will not align in order make contact with that switch. or you may have a faulty light switch
Oct 20, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
ARISTON FRIDGE FREEZER MBA 3842C PROBLEM
It should work the same as before. Does the compressor get really hot after running a while? If so it could be low on charge, or there could be a restriction inside the refrigeration system. Either way a professional would have to look at it.
Jan 07, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
AEG Santo 3888 KG8 Bottom Freezer Refrigerator Logo
228 people viewed this question
Top AEG Refrigerators Experts
Oscar Netto
Oscar Netto
Jim Goldsmith
Jim Goldsmith
Are you an AEG Refrigerator Expert? Answer questions, earn points and help others
