Question about GE 30" Built-In Single Electric Wall Oven - Bisque-on-Bisque
Oven shuts off 10 minutes into self clean cycle or while broiling
After shutting down, the "locked door" message comes on and the door goes through a locking/unlocking cycle for another 10 minutes. There is no error codes.
  • 106 Answers
Check for loose connection on the door sensor or micro switch you ay need to change the micro swich if faulty
Posted on Jul 28, 2010
Scholtes FE46 and the door is locked. Also no clock/timer lights. Temp/function and oven work but is locked even though completely cold.
Here are a couple of things to try:
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
Read through the following for mire info:
Appliance411 FAQ After self clean range oven door won open
Mar 25, 2016 | Ovens
Door locked after self clean cycle.
Ensure you let the oven cool down completely after a clean cycle before trying to open the door.
If the door still won't open after a couple hours of cooling down, then go to the main power panel in your house and shut off the breaker to the oven. Leave it off for 5 minutes, then switch it back on again.
Then try the oven door again.
Good luck.
Feb 28, 2011 | Viking Ovens
Tried to clean single Electrolux wall oven. The cycle began, the door locked and then the oven shut down with the door locked. I shut off the breaker for 10 minutes and then back on, no change. I checked...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 20, 2011 | Electrolux ICON 30 in. Double Wall Oven
We have a kenmore model# 911.47692100, oven with a self-cleaning cycle that does not want to work. Following the instructions we push CLEAN, the 4 hour display comes on, we push START and the LOCK DOOR...
The oven self clean heats the oven in excess of 450 degrees. It will not begin until the door is properly closed and the slide lock goes completely home. This is to prevent anyone being able to get into the oven until after the cleaning cycle is done. When your "door lock" indicator blinks and beeps, try the door to see if it is really locked. If not, shut off the system and try to find out why it is not locking properly. If you find the reason and fix it, it will probably work properly.
Jan 01, 2018 | Ovens
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
My oven door will not shut all the way. It
It is probably the self-cleaning latch that keeps the door from being opened during the self-cleaning cycle. Looks like it didn't retract all the way. Did you use the self-cleaning cycle? . Do this: Quiet the house down, open the door slightly and close it, letting it hit the obstruction. Do this again and again. You don't have to close it hard at all; in fact, do it gently. By listening, you will be able to hone in what is keeping it opened. Then go from there.
Nov 25, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I need an owner manuel for Caloric Range Model # EST 345 I can'g figure out how to run the self cleaning oven cycle.
you might try the following, although it is the instructions for an old model, it may be relevant;
"The actual self-cleaning process is initiated by a simple 5 step procedure: 1. Set the range clock to time of day. Note: on models not equipped with an automatic oven timer, the self-cleaning cycle is preprogrammed for a 21/2 hour cycle. Use Steps 3, 4 and 5 only. 2.Establish the length of cleaning time by:
A. Setting the start time. Press and turn the start dial of the automatic oven timer clockwise to the desired starting time. B. Set the stop time. Press and turn the stop dial of the automatic oven timer clockwise to the desired stop time. Max time is 3 hours miniumum 1/12 hours. 3. Set the oven selector dial on the control panel to "Clean" 4. Set the temperature control dial to "off". If you temperature control dial has a "Clean" position, then set the dial to "Clean" instead of "Off". 5. Remove oven racks, broiler pan and broiler grid from lower oven. Close and lock the oven door by moving the latch lever as far right as it will go - into the locked position. If the lever is accidently dislodged restore it to the locked position. Otherwise, the self-cleaning process will not take place. Shortly after the cleaning cycle has begun, the oven temperatur reaches a degree in excess of the normal broiling temperature. The red "Clean" light will come on and the clean cycle will start. In a few minutes the door lock lever, which you have placed in the locked position, will automatically be secured to prevent the oven door from beging opened during the cleaning cycle. This latch remains locked until the clean cycle is complete and the oven temperature reduces to normal baking and broiling temperaturs. NOTE: Prior to self cleaning cycle operation, the oven and surface lights must be turned offed. The upper oven can be used."
I found this here; http://www.appliance411.com/archive/21155_caloric_oven_lost_cleaning_manual.shtml
Nov 18, 2009 | Ovens
We have a GE convection oven. Every time I go to turn on the oven, the words "DOOR" come on and then the oven shuts off. So frustrating. My husband's hungry!
there are several possible causes for this symptom. The most common are...in my experience.
1) the self clean monitor switch is "open" (have you recently done a self-clean cycle ?)
2) the electronic relay control (erc) is faulty. (hopefully not)
It is most likely the first possible cause. The first thing to try of which you can do on your own is shutting off the 40amp breaker to the unit for a couple of minutes, or unplugging the unit from the wall, they both accomplish the same thing. If that doesn't yield any remedy, try selecting a self clean cycle, allow the door to lock, then cancel the cycle and allow it to unlock. The lock switch (s) may just be stuck in the wrong position for normal bake and broil operations.
Let me know how that goes and we'll deal with whatever happens as a result, hopefully success and a yummy supper for everyone !
Good Luck :)
Oct 21, 2009 | GE Ovens
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
GE 30" Built-In Single Electric Wall Oven - Bisque-on-Bisque Logo
106 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
