Question about Canon Cameras
Non opening of lens
Ref ixus 750 Pictures can be viewed but switching to taking, len opens slightly and camera turns off. (Battery is fully charged)
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 28, 2010
I have cannon digital camera IXUS 255 HS. I
Dear Tejas Belani,
I hope you're still reading this but I had exactly the same problem with the Ixus 255 HS as you describe (full battery - false message - filled battery icon when looking to pictures on the memory card).
After some failed rescue attempts (recharging, completely discharging, 10 second hold of on/off button), I think I finally found it: put a small piece of paper or carton in between the battery opening door and the battery. This pushes the battery a couple of millimeters deeper in the battery bay and ensures a good contact between battery and pins at the other end.
Seems like Canon were a bit cheap on the plastic levers that secure the battery ... or perhaps they erode after some time of usage. This type of camera is often exposed to more aggressive conditions than the bigger, more expensive camera's out there :)
Aug 20, 2013 | Canon Cameras
My Canon Digital IXUS 960 IS camera will not turn on despite having the battery fully charged. What is wrong with it?
Is the battery powerfull enough? Meaning has enough DC current in it to powerup? There are 2 "ON" buttons one at which the lens comes out, the second to view pictures.
Jun 28, 2011 | Canon IXUS 960 IS Digital Camera
I put in my battery after charging and the camera opened but it will not take pictures. The lens will note retract. when I press the on button the green light comes on but the camera buzzes and nothing...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 24, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
My lens for my ixus 750 is stuck open. when
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Nov 09, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
When turning on camera the lens will open then shut off on a fully charged battery. It will allow you to view pictures on the camera by selecting the favorites and turning it on but when you turn the...
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Your batt. is covered under the same man. warranty as your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 05, 2009 | Kodak EasyShare M863 Digital Camera
When i turn on the camera the lens wont pop open even when the battery is fully charged.... i was taking pictures and it working fine turn the camera off and on again then the lens wont open anymore? i can...
The problem is
1- some dirt somehow got on the outside of the lense. After it was retracted fully in, it prevents the camera from opening again. When you turn it on, if it opens a little bit, try to pull it out NOT too hard and let go a few times. If it opened, clear the outside of the lense. Your camera should be back to normal.
2- If you droped the camera, you probably damaged or dislocated a mechanical part of the lense. You may have to take out the lense by unscrewing it and inspect it for damged parts or disconnected cable. Make sure clean the lense and test it by moving it in and out a few times, before puting it back on the camera.
Good luck!!!!!!!
Jun 10, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Canon ixus 50 the camera is not switching on and the lens is open
Check the battery cover closes properly, the camera will not operate at all if the switch thinks the cover is even slightly open. Try removing the card, sometimes they cause cameras to not start when they are faulty. If all else fails, the fuse is most likely blown. They are internally located just near the power switch but you are best to have a service centre replace it for you. Best of luck.
Apr 15, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Sony Cybershot DSC-W90
I had the same problem, I gently pried open the black windows of the shutter with my index finger nail, and applied very gentle pressure (pulling outward) while I pressed the power button. THEN... the whole zoom assembly moved EVER SO SLIGHTLY. So, I repeated the exact same process, with a little bit of pressure... and voila... the lens assembly opened fully and I was able to take pictures.
Jan 14, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Lines appear
normally that problem occurs when the obturator is allways opened, to be fixed needs to exchange the lens
Jan 22, 2007 | Canon PowerShot S410 / IXUS 430 Digital...
Cameras Logo
29 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
