Question about IBM ThinkCentre A50 PC Desktop
PC takes 3 to 5 minutes to boot - reduct it?
My computer takes 3 to 5 minutes to boot up - can I reduce it?
  • 565 Answers
You may have a lot of (unnecessary) software that is trying to load at startup. Download "Autoruns" and disable some of them from starting (they will still be available, they just won't be running at startup):
http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
You may also have malware that is causing the problem. Try this:
http://www.malwarebytes.org/
Here is a tip that may help:
http://www.fixya.com/support/r3760943-fix_slow_computer
Posted on Jul 28, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
If you are using windows machine, go to start->run and type cleanmgr.exe and follow the instructions to clean up the junk and temporary files in your machine.
Also go to start->run and type msconfig and go to Startup tab and remove all the unnecessary startup items.
Also uninstall unwanted programs/applications from control panel (start->controlpanel) and go to add or remove programs / Programs and features based on your operating system version.
Now you can clean up your registry values using http://www.pctools.com/registry-mechanic/ or some other software available in the market.
Once you have done this if you know you have many unused useless files in your machine remove then and do a fresh restart. Then defrag your drives using the utility available in windows (go to my computer and right click on the drive you need to defragment and then click on the properties in the pop down menu. Once you are in properties window go to tools tab and click on defragment now). After the defragmenting is complete you can restart your machine again and you will notice a significant performance boost.
More than everything you need to make sure your machine is malware free; viruses and malware are one of the major reasons for systems being slow. So run a thorough Antivirus and Anti Spyware checking using some standard antivirus software and anti spyware software.
Hope this will help you.
Best Regards NextDoorNerd
Network controller driver increases the booting time to an hour
Hi. Chaek if you have a flash drive, SD Cards or any USB devices connected to your computer when you turn it on. If you have, then remove them.
You can also try to disable most start up rograms by going to Start, Run then type msconfig... click start-up tab and click disable all. Don't forget to leave a checkmark on your antivirus!
Hope that'll help!
^_^
May 15, 2010 | Dell Precision M70 Notebook
My MFC-3240c won't copy. Has been fine up to now
Hello may I suggest doing a simple reset of your machine. If you have not tried this please do so.
Simply unplug your printer power wire from the printer and wait about a minute. Now plug it back in and your problem may be resolved.
Next, if this does not make sure you do not have any print jobs backed up in your computers printer cue.
This can be done by looking in the bottom right corner of your computer monitor. look for a printer icon. If there is on there click on it and cancel all print jobs.
Also, check for paper jam, make sure paper is not causing problem.
_________________________________________-
finally, here are the steps to enlarge and reduce. just in case there is a step you are missing.
Press options: UP or Down arrow.
Enlarging or reducing the image copied
You can select the following enlargement or reduction ratios.
Custom(25-400%) allows you to enter a ratio from 25% to 400%.
1 Press (Copy) to illuminate it in green.
2 Load your document.
3 Use the dial pad to enter the number of copies you want
(up to 99).
4 Press Options and ▲ or ▼ to
5 Press ▲ or ▼ to select the enlargement or reduction ratio you
want.
Press Menu/Set.
—OR—
You can select Custom(25-400%) and press Menu/Set.
Use the dial pad to enter an enlargement or reduction ratio from
25% to 400%.
Press Menu/Set.
(For example, press 5 3 to enter 53%.)
6 Press Black Start or Color Start.
Mar 28, 2010 | Brother MFC-3240C All-In-One InkJet...
BLOTCHES ON SCREEN
This may not be the problem, but the following service bulletin may be of interest:
Last Update: 1/25/2006
Document Reference/Event ID: E30094243
Model: KDSR50XBR1, KDSR60XBR1
Subject: Picture might have a slight Greenish tint.
SYMPTOMS
Under certain conditions (especially cold/ first power ON), white areas of the picture may take on a slightly greenish tint after power on until internal temperature stabilization is achieved. Typically, this disappears after approximately 10 minutes operating time, however, in certain cases (i.e. colder conditions) the set will continue to fine tune the picture longer that 10 minutes. This is in order to create optimum picture performance under nominal viewing conditions.
This is not a defect but a characteristic of the LCD panels. Be assured that the time it takes to disappear will neither lengthen nor reduce over time.
If the condition improves but reduction in effect is desired, there are customer adjustments that can minimize this condition. Please demonstrate these adjustments with the customer, to determine if these settings are acceptable. (User adjustments are supplied in Solution A)
In cases where no Uniformity improvement is achieved (after 30 minutes power on time) proceed to Solution B; Optical block
Note:
Please be aware that all Optical Blocks exhibit warm-up behavior.
Replacing an Optical Block will not eliminate or significantly reduce the time below 10 minutes.
RESOLUTION
CAUSE:
Internal temperature stabilization needed.
Solution A)
You may reduce this effect by changing some user settings as follows:
(1) Change the Color Temperature setting to Cool - (refer to page 81-82 of the instruction manual). If further reduction is desired proceed to step 2.
(2) Slightly Reduce the Green bias (only available in PRO Picture mode under Advanced video settings), then select white balance Adjustment - (refer to page 81 of the instruction manual). Example:
a. Menu, Video, Picture Mode, Pro Mode
b. Menu, Video, Advance Video, White Balance, G-Bias (Reduce several steps)
Solution B)
Replace Optical block after gaining approval from Sony Tech. line.
Jan 23, 2008 | Sony KDS-R50XBR1 50" HDTV
Red eye reduction
while in record mode, press the flash/up button repeatedly until you are in red-eye reduction mode. red-eye reduction mode should greatly reduce the problem when enabled. If this does not work, the software that came with your camera (and most photo editing applications) include a red eye reduction/removal filter.
hope this helps,
trin
Nov 17, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Noise Reduction
This function reduces the noise that generated during long exposures. When shooting night scenes, shutter speeds become slower and noise tends to appear on images. When noise reduction is turned on the camera automatically reduces noise to produce clearer images. Since shooting time is approximately twice as long as usual, noise reduction is only activated when the shutter speed is slower than 1 second.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Noise Reduction
This function reduces the noise that generated during long exposures. When shooting night scenes, shutter speeds become slower and noise tends to appear on images. When Noise Reduction is set to ON, the camera automatically reduces noise to produce clearer images. However, shooting time is approximately twice as long as usual.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Noise Reduction
This function reduces the noise that generated during long exposures. When shooting night scenes, shutter speeds become slower and noise tends to appear on images. When noise Reduction is set to ON, the camera automatically reduces noise to produce clearer images. However, shooting time is approximately twice as long as usual. Noise Reduction is only activated when the shutter speed is slower than 1 second.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Noise Reduction
The Noise Reduction function reduces the noise that is generated during long exposures. When shooting night scenes, shutter speeds become slower and noise tends to appear on images. Turning this function on will reduce the amount of noise in the image.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Noise Reduction
Sep 01, 2005 | Olympus Camedia C-5000 Zoom Digital Camera
IBM ThinkCentre A50 PC Desktop Logo
80 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
