Question about Acer Aspire 6920 Notebook PC
My acer will not load it has the option of loading safe mode or normal and i click on either and all i get is a blank screen help?
  • Acer Master
  • 11,800 Answers
Windows is corrupted beyond repair. The only thing you can do is to reinstall it.
Posted on Jul 28, 2010
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
COMPUTER TURNS ON, BUT THERES NO START UP AND SCREEN IS BLANK
Try to go to Safe Mode by reseting the computer then tapping F8. If your able to acces safe mode follow these instructions:
1. Go to start then click on RUN
2. Type msconfig
3. go to services tab, click hide microsoft services then click disable all
4. reboot the computer and see it it will go to normal mode. It you will be able to boot to normal mode it only means that one of the isntalled software is preventing windows to load
5. if still cant boot you neet to reformat the system
Thanks for using Fixya.
Jan 24, 2011 | Acer Aspire M1641-U1521A PC Desktop
My Acer Aspire One only loads in Safe mod. I cann't run any diagnostick tools like Hirm's Boot CD from an external CD drive, which is connected via USB.
This happens when set you PC on Safeboot Option.
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 18, 2010 | Acer Aspire One Netbook 8.9" Notebook
Remove printer drivers
You can check your laptop further by booting it from Safe Mode. To boot your computer in Safe Mode, try to tap continuously F8 function key on your keyboard immediately when you start your computer. It will lead you to an Advanced Menu from where you can choose the option "Safe Mode" and hit enter to boot your computer to safe mode. Now try to check the display driver in the device manager (Control Panel >System > Hardware >Device Manager) If it is not there, try to reduce the screen resolution and reboot your computer to the normal mode. If you are still getting the blank screen in Normal mode, try to boot computer back in Safe Mode and try to restore your computer to earlier time when it was working fine for you. To do so click on Start Menu > All Programs > Accessories > System Tools > System Restore. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next. On the Select a Restore Point page, click the most recent system restore point in the "On this list, click a restore point" list, and then click Next. Now confirm the restoration and click on Next to complete the restoration and follow the wizard.
Cheers!
Mar 28, 2010 | Acer Aspire One AOA110-1588 Notebook
My Acer Aspire 1500 laptop wont pass startup.
It seems that your laptop hardware is good and it seems that it is a software issue.
  1. Boot in safe mode: When your laptop start, press the F8 key. then it will ask you which boot device to boot from, browse using the arrow keys and chose something with HDD and press ENTER and then press the F8 key again. Then you will be given a boot option and choose SAFE MODE.
  2. While in SAFE MODE, try to uninstall your newly installed software that might be causing the laptop to hung up.
  3. Also, click Start => Run then type: msconfig.
  4. Go to the Startup Tab and uncheck the many programs that looks not necessary to load while windows is loading. The program like Yahoo Messenger, Skype can be opened manually so uncheck them if present.
  5. Click Apply then OK.
  6. Restart your laptop and see if it helps.
Feb 23, 2010 | Computers & Internet
Load up acer and screen black with arrow cursor only thing that works
registry or some Windows DLL files r corrupt...
try this..
restart, before u get the Windows screen press F8...
choose option load in Safe Mode
if Safe Mode loads and u get the desktop, try downloading Tuneup Utility from internet, install that and clean ur registry
then shut down and restart....
let it load in Normal mode....
let me know if that works else we can work some other solution
Dec 20, 2009 | Computers & Internet
Hello I wonder if you can help. When we switch
Had a similar problem like this several times. Try choosing safe mode. Safe mode will load the required drivers. After safe mode finishes the loading process, restart your computer and choose to start windows normally. The problem you mention usually happens when the computer is turned off without using normal shut down procedures. Also happens when you have a sudden power outage.
Oct 24, 2009 | Computers & Internet
Hey i need help quickly on this laptop
Your having data corruption. I think you should consider the REPAIR options or factory restore if it have that cd for the last options.
Just for an input.
Apr 28, 2009 | Medion (40010998)
Booting problem
You may have to boot from a CD and make a repair.
Once logged in the CD, choose repair option (Recovery Console), and type these three commands:
1) fixmbr (wait til it finishes)
2) fixboot (wait...)
3) CHKDSK (this will take longer than the previous two.
Your laptop may now boot normally. I think your laptop doesn't have an internal CD-ROM so you may use an external USB CD.
Apr 22, 2009 | Computers & Internet
Computer will not load.
use safe mode..do a disc clean, defrag..and then reboot...sounds like the operating system headers went unhappy when you moved it(which I highly recommend you NOT do again)..
May 25, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Acer Aspire 6920 Notebook PC Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
