Question about Husqvarna 28cc Gas Line Trimmer
Need to find carburetor repair kit (Part No. 501950901) for my Husqvarna Model 25r trimmer. Also head gasket for this trimmer. Any Help?
3 Suggested Answers
  • 395 Answers
SOURCE: Looked everywhere and can't find owner's manual
Have you try at this page? www.husqvarna.com/us/homeowner/support/download-manuals/
The model number should come with at least one letter and 3 numbers. Can you check your model number again? Thanks
Posted on Jun 12, 2011
  • 250 Answers
SOURCE: in what order does a carburetor gasket kit go on a
There is only one gasket, Jenny. To figure ouut which way it goes, first put it onto the carby, then transfer it to the motor. Next put on the carby, and tighten the screws. Then hook up the electrical wiring and the fuel lines, and the job's done.
Posted on Jun 17, 2011
How do i remove/replace the choke lever on my model 128cd trimmer? I have the carburater cover off but i cannot get the lever to slide off the rod.
I do not believe this lever comes loose from the carburetor. When a kit is ordered, the lever comes with the carburetor kit.
Jun 08, 2014 | Husqvarna 28cc Gas Line Trimmer
Husqvarna 25r - is this a good model?
The 25R was a badged engineered machine ( not made by Husqvarna ) the first model was a Mitsubushi engine, the later version was a Mariama, both were good machines in there day, they were offered with a line head and a grass blade, they were as you can guess approximatly 25cc, the early version had points condensor ignition, and later on had electronic, parts are now becoming hard to get, so be aware.
May 14, 2013 | Garden
I need a operating manual for a Husqvarna 25r weed trimer
This is the closest I could get to your exact model. There is a 250R on the site (which includes other models as well). This is the manual for a Husqvarna 26r.
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/26_r.html?idRes=12881032
Sep 10, 2011 | Husqvarna Garden
I have a 25cc weedeater 358791030.I need a gasket repair kit for inside of carb. Sears told me they do not have repair kits for inside of carb only a gasket for carb mount.Any suggestions........Thank you.
Look on the body of your carburetor. There should be a set or two of numbers molded into it. Take these #s (they're the model # of your carburetor) and enter them into the Cross-Reference Page on PartsBuggy.com's website. If there is a kit available for the carburetor, you'll find it there.
Jul 12, 2011 | Craftsman 25cc Gas Line Trimmer
In what order does a carburetor gasket kit go on a husqvarna 125L weed trimmer
Jun 16, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
Husquvarna gas trimmer model 25r need a carburator kit which we cannot find
I am thinking that this is your model and model year (25R 1986-2010 Line Trimmer). Here it is.
Keep record of the carburetor kit part number in case you find it elsewhere for maybe a lower price.
http://www.ereplacementparts.com/husqvarna-198610-line-trimmer-parts-c-114486_117795_118780.html
If this is NOT your trimmer, you can look around on this site till you find it. There are many Huskys listed and a few of them bearing the model number you have given. I hope this helps.
Dec 14, 2010 | Garden
I have a craftsman hedge trimmer ordered a carb rebuild kit. it was mas with a Husqvarna carb, parts arrived marked husqvarna 530-069969 rebuild kit. I need a diagram to put pack toget her. Please help
Go to: http://www.drystacked.com for a 12 page article on Walbro brand carburetor theory and troubleshooting. This information applies to other brands of carburetor as well. Hope this helps!
Aug 14, 2010 | Husqvarna Garden
Unable to adjust carburetor after overhauling, engine idle
most modern carbies have fixed jets.some you can pry off the caps and adjust,but usually if you need to adjust carbie,youve got other problems.stale fuel,not enough compression,vaccuum leak,spark plug faulty[oiled up]carb gaskets letting in air,needle valve adjustment causing diapragm to not open it enough.used the wrong gaskets in the kit[sometimes they have different model gaskets in one kit
Jun 29, 2010 | Echo Garden
I need a drawing of a carburettor on a 61 Huaqarrna chain saw\r\nwhere do I get it? It is a husqvarna Chain saw
You didn't specify of its a 61 or a 61 Rancher. Here's the info you need to take to your Husky dealer. The diagram will be with the major repair kit.
Model 61, then the 61 Rancher:
CARBURETOR Model 61: ecblank.gif Tillotson HS-163A, B , HS-254A series or
Walbro WS series
MAJOR REPAIR KIT: ecblank.gif RK-23HS for HS-163A MINOR REPAIR KIT: ecblank.gif DG-5HS/T for HS-163A
CARBURETOR Model 61 Rancher: ecblank.gif Tillotson HS-163A series or
Walbro WS-17A, B series
K10-WS
D10-WS
May 18, 2010 | Husqvarna Garden
I have a Ryobi string trimmer that will start quickly, but will not keep running unless the choke is ~ 3/4's closed. I've already rebuilt the carburetor, but that didn't help.
Have you ordered a gasket kit for it? If you have already rebuilt the carburetor and still having this problem most likely means you have a vacuum leak somewhere. Take the carburetor off and look at the intake manifold, there is a gasket on both sides. A gasket kit will allow you to replace both of those gaskets which should fix your problem...hope this helps.
Sep 14, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Husqvarna 28cc Gas Line Trimmer Logo
62 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
