Question about Kenmore 62602 Electric Dryer
Electric Dryer (Kenmore) It Doesn't spin
I have a problem with my electric dryer. It has heat and the vent is working fine but it doesn't spin
  • Bellpoint May 03, 2008
    everything seems fine, just won't spin. Belt came off
  • DB LYNCH May 11, 2008
    how do you replace the belt ?
My other problem is that I can't seems to find where I need to put the belt into
Posted on May 01, 2008
  • 145 Answers
The motor has to start to close a switch to let it heat so it sounds like you need a new belt.
Posted on Apr 24, 2008
Dryer vent was cloged now heat dosent work
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-200-865057-/LG-Dryer-doesn-t-heat-DLEX2501V
Sep 01, 2014 | LG dlex2501v front load steam electric...
Runs fine Doesn't dry clothes, not enough heat?
You will first need to determine where the problem is, I would disconnect the dryer vent from the dryer. Now if the drying improves, problem is not the dryer, its the vent system. If no change, does the unit heat at first then slowly fail to heat? Does it produce any heat? I need more information to direct you in the correct direction.
Please get back to me
Sep 08, 2011 | KitchenAid KEYS700LQ Electric Dryer
Dryer turns on and lights , heats approx. 1 min. goes out when up to temp, stays off approx 1min. lights again, may do this for 5 times then just doesn't relight. Stays cold, keeps spinning drum. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | GE DCVH515GF Gas Dryer
Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
heatman101';
Aug 11, 2011 | Dryers
Dryer spins, but no heat. vent is not plugged. when dryer spins only cold air from the vent
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 11, 2010 | Dryers
Dryer spins, but no heat. We have checked the circuit breaker and it is fine. The exhaust vent is clean.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 09, 2010 | LG DLE2514 Electric Dryer
My kenmore 600 gas dryer dont heat up. gas is on electricity its fine it turn on it works fine but just not heats up.
Disconnect the rear vent off the dryer itself and try again. If heat does work the vent tubing is clogged
Oct 06, 2010 | Kenmore 600 6962 Dryer
My Kenmore Elite dryer spins with no heat
please check the thermal cutoff. these are the parts with 2 thick wires attached to it. they are normally located near the heating element ( if electrical ) and (near the exhaust if it is gas).
these parts control the heating element.
tnx 4 using fixya,
drcool
Nov 05, 2008 | Kenmore 73952 Gas Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Kenmore 62602 Electric Dryer Logo
107 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
