Question about Sony Cyber-Shot DSC-F828 Digital Camera
The problem I'm having with my Sony DSC F828 is that the mobile lens has come loose from the body of the camera. There are no obvious screws visible that would stabilise it. I have read that it is a commin problem for this model. I would be grateful if you could help me find a solution. Should I take it in to get it fixed professionally or can I do it myself? thank you
  • 3 Answers
Hi, I had the same problem. I have done a comprehensive repair which I have documented on my blogsite: http://howtheheckdididothat.blogspot.com/2010_10_01_archive.html There are lots of pictures and step by step instructions. Hopefully this will fix your problem.
Posted on Oct 28, 2010
I need to replace the lens hood for my Sony dsc f828 . What size should I be looking for ? 55 mm ? Thanks
The lens thred is 58mm on F828, however a 58mm lens hood does not work; I have both a reverseable and a regular 58mm flower hood that extends 1/2" to the front of the lens causing dark corners on 28mm focal length. In addition, the lens itseft has built in receiver for hood as labled in the manual, I am thinking to get a 62mm or 60mm reversable hood and match up with the receiver on the lens
Dec 04, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
My DSC f828 sony camera's lens is loose. Sony says it is not worth repairing. Surely there must be a way to fix this ? thanks
I'm not sure what you mean by "loose". Does it still take good pictures? If not, then Sony is correct...the camera was introduced in 2003 and the cost of repair would far exceed the camera's worth.
Oct 01, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
After having the f828 in my luggage the lens and the body are not tight together anymore. when i hold the lens with my left hand the body joggles left an right? can i unscrew the camera and tighten a screw...
I fixed that problem by tightening up screws but they were inside the lens turret swivel mechanism. This required some fairly major surgery to get to them and it was a bit intimidating. I carefully noted all the steps, took plenty of photos on the way using the Nikon macro, and consulted the service manual. The outcome was a fully restored and serviceable F828 which, despite its age is going on holiday with me again soon to the South Pacific. All the detail for the surgery is on http://howtheheckdididothat.blogspot.com/ I hope that helps you and the many others I know have had the same problem. Good luck - I hope you have it fixed after all this time. The F828 is still hard to beat in many respects.
Jan 02, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
I am missing several little screws on the bottom of the cybershot DSC-F828. Camera is loose but functions fine
You might try going to a place that repairs watches and jewelry...they usually keep an assortment of tiny screws on hand.
Dec 07, 2009 | Sony Cyber-Shot DSC-F828 Digital Camera
Reassemble the camera lens
Hi, i have provided some disassembly and reassembly detail on my blogsite to deal with a loose lens problem. The site has a link to the service manuals which might help, otherwise my detail might be all you need. See: http://howtheheckdididothat.blogspot.com/2010_10_01_archive.html There are lots of pictures and step by step instructions. Hopefully this will fix your problem.
Aug 24, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Mechanical problem
Undo the six M2 screws that hold the left housing assemble (control panel for flash & focus etc) and remove You will see that there are 3 srews that hold the hinge assembly together all 3 wiil be loose and require tightening (you will neeed to tilt the lens up to see and tighten the third screw.
Reassemble the housing making sure not to trap thw flexible cable
Easy 5 min job
Jul 29, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
Lens is loose from body
One note on this fix. There are four screws that need to be tightened on the lens. With the cover off and the lens pointing straight forward, there are three small screws visible. After tightening them, rotate the lens upward to expose the fourth screww. After that one is tightened, you can then replace the cover and six cover screws.
Jan 18, 2008 | Sony Cyber-Shot DSC-F828 Digital Camera
F828 32x Flash conx probs
Do you have the camera set for flash? If it were set for no flash (diagonal bar thru lighting bolt) the F32X and the camera do not communicate.
Sep 12, 2005 | Sony Cyber-Shot DSC-F828 Digital Camera
How do I change lens orientation on my F828?
Just move it. I assume you're talking about the swivel? It's just a friction joint. Hold the body and rotate the lens up or down.
Sony Cyber-Shot DSC-F828 Digital Camera Logo
238 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
