Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
MY SEAGATE WILL POWER ON BUT WHEN I CONNECT IT TO THE PC IT DOES NOT SHOW UP AS A CONNECTED DRIVE. NO ERRORS OR INFORMATION REQUESTING DRIVERS. WOULD THE LACK OF DRIVERS CAUSE THIS PROBLEM. tHE POWER IS CONNECTED AND A USB IS CONNECTED FROM THE SEAGATE TO THE PC.
    Genius:
  • 1,478 Answers
When the USB cable is connected properly (and your computer is on) a light appears in the center of the Pocket Hard Drive. This light indicates that the Pocket Hard Drive is receiving power and is ready to use.
If this light does not come on and your Pocket Hard Drive isn't recognized by your operating system.
To see the files on the drive, double-click on the My Computer icon on your desktop. You will see your Pocket Hard Drive represented with the default "Removable Disk" label. After the system detects the drive, the light in the center of the drive becomes a drive activity indicator. This means the light will flicker on and off when your computer is accessing the drive.
Take care.
Posted on Jul 28, 2010
  • govalle1020 Jul 29, 2010
    The light comes on when I power the Seagate, I also hear a few beeps coming from the Seagate as it's booting (few seconds). When I go to the my computer tab I still don't see the external hard drive as an icon. Could the hard drive be dead? Do I need to load drivers specific to this Seagate? It's a 500 GB that was given to me.
  • Jimoh Adeleke Muyideen Jul 29, 2010
    I will suggest you try to use your seagate with another system and see if it recognizes it, if it did not, it means the operating system on system can not recognize your seagate. I will advice you get the driver of the seagate, install on your system, with that, your seagate should be recognize because if the light in the center of the Pocket Hard Drive. This light
    indicates that
    the Pocket Hard Drive is receiving power and is ready to use. which indicate it is still good. Try use it with another system and see if it works, if not, get the driver installed on your system.
    Take care.
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
SEAGATE FREEAGENT GO 320 GB USB HARD DRIVE P/N 9KW2AG-502 320GB SN:2GE7114P THIS HARD DRIVE NOT SHOW IN MY PC SO I REQUEST YOU TO SOLVE MY PROBLEM...... THANKS
Feb 24, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My portable HD detect pc, but no driver found and cpould'nt open
If it shows up in my computer then just double click on it as you would the C drive or dvd or cd it should put the driver in already if it is showing remove safely sometimes it will require a reboot after it is installed
Jul 07, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Dear ... I have recently purchased Seagate's Freeagent External Hard Drive (500 GB Capacity). It was working all right for about 10 Days, but now I face a peculiar Problem. This drive does not show in the...
Plug it back in and try this. Right click my computer and click "Manage"
When the window opens select "Disc Management". In the bottom of the screen you will see all the Disk drives installed on you computer. Right click on your drive and select "Properties". When the window open click the "Tools" tab and finally Run the Error Checking Tool. It will scan and fix any issues with the disk. Cheers :)
Jun 27, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Drive is asking to be reformatted?
Yes your assuumtion is correct, you WILL loose all your data.
I have been there before.... and the outcome was not good.
If your PC will recognize the drive and give it a drive letter, you can run chkdsk (Check Disk) from the Run prompt to verify that the drive does not have damaged sectors. many times chkdsk will fix minor errors allowing you to access the drive again.
Click Start, Run CMD, enter, then type: X: (X being the drive letter of the Seagate) then type chkdsk /r and hit enter. If it completes 100% try accessing the drive again.
If you cannot acquire a drive Letter when you plug in the Seagate try going to Disk Management and assigning a drive letter.
Click Start, then Right click on My Computer and click Manage, then click Disk Management. See if your Seagate drive shows up in the list. If it does, right click on the larger box on the right and see if it will allow you to assign a drive letter.
Another option you may have is taking the hard drive out of the Seagate enclosure and either connecting it as a secondary drive in a desktop PC, or installing it into another external enclsure USB device, and try again to access the drive.
If none of these options work, your last option is to contract a Disk Recovery Service to acquire your data. They are usually very expensive.
Jun 15, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
117 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
