Question about Ovens
The Oven is overheating on my Indesit FIE56 K.BIX GB Oven. How do I change the oven thermostats
  • 1462 Answers
SOURCE: oven not heating up but fan and light on
circular element is open circuit. reasonable cost part and reasonable to fit
Posted on Jul 05, 2008
barkencoa
  • 3463 Answers
SOURCE: Neff U1422 oven overheating
Hi
Yes it does sound like faulty thermostat.
You will have to remove the oven from the oven housing, and remove the top cover, and possibly the front console.
Then you will have trace the sensor back to the main oven, and unfasten sensor in oven
You will probably have to remove the rear
panel as well to get the thermostat sensor out.
One other possibility is the sensor may have become detached inside the oven, this will then affect the oven temp.
Good luck
Hope this will prove helpful.
Posted on Nov 22, 2008
  • 12 Answers
SOURCE: indesit fde20 main oven wont heat up
sounds like the circular element at the back of oven has blown.
Posted on Oct 24, 2009
  • 417 Answers
SOURCE: The symbols on my Indesit oven have literally
There is no easy solution to this.
Either you can replace the parts that are worn or you learn where the marks should be and make the best of it, have you contacted Indesit direct about the problem? this really should not happen on an oven just 2 yrs old.
You can probably print off a copy of the original detail for reference from www.indesit.co.uk, parts can be obtained from www.4indesit.co.uk
Hope this is of some help.
Posted on Jan 04, 2010
SOURCE: wattage for double oven
im getting a indesit fid201 double oven does it have to be hard wired or can it go on a 13amp plug
Posted on Mar 17, 2010
Main Oven Overheating
Try putting thermoter in oven take off main dial you well see a small screw ajust slowly and check every 30min.tell temp is correct.and put dial back on
Jul 26, 2010 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
OVEN OVERHEATING
thermostats are not the sane. make sure cooling fan is working as this is more likely to cause the oven to cut out
Jul 23, 2010 | Electrolux EOD6390X Electric Double Oven
My indesit electric oven cuts out after about twenty minutes, will not switch on again until it cools. is this caused by a faulty thermostat?
It is probably the overheat safety thermostat that is operating due to oven overheating.
Check to see if the top cooling fan is working, and if it is built in, make sure it has adequate ventilation.
Please rate my advice.
Thankyou.
Jun 04, 2009 | Ovens
Need instruction manual for operating Indesit Automatic Oven
I have a indesit oven and not sure what model it is because i have no manual, its silver, has 3 control knobs and six small under the small digital screen, it has 1 door at the top which is blacked out cannot see through and the bottom door is clear glass, any ideas?
Mar 02, 2009 | Ovens
Electric fan oven overheating
It sounds like the thermostat is faulty, make sure the sensor is not detached inside the oven compartment, as this will affect the thermostatI if it is. If o/k, then the only option is to replace the thermostat. If it is fan assisted, then make sure the fan is working o/k as well.
Please leave a rating for my comments.
Thganks.
Mar 01, 2009 | Equipex PZ-330 Electric Single Oven
Hi
Good luck
Nov 22, 2008 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
