Question about Minolta EP4000/5000 CS/PRO Copier
Toner does not print onto copier paper - Minolta EP4000/5000 CS/PRO Copier
  • Minolta Master
  • 1,297 Answers
Verify the fixing unit,your fixing lamp or thermistors is in malfunctioned.Clean the thermistors,thermalfuses or the thermal lamp located in the fuser unit.
Posted on Aug 09, 2010
Display board shows TONER EMPTY REPLACE TONER .
Its telling you its out of toner (the print you see is toner burnt onto the paper). You will need to buy some more and fit it as per the instructions in your user book.
May 10, 2011 | Samsung SCX-4300 Monochrome Laser...
Tuner exhausted replace tuner
A laser printer uses toner powder to print onto paper. When the toner runs out the toner cartridge needs to be replaced so you can continue printing.
You can purchase a new toner cartridge for your model printer, or a cheaper alternative is to purchase a recharged/re-manufactured toner cartridge.
Jan 14, 2011 | Samsung SCX-4300 Monochrome Laser...
Poor print quality
The "ghost" image is "burned" onto the drum.
A laser printer is supposed to charge specific "dots" on the drum, and the toner-ink is supposed to stick only to those "dots", the paper is pressed against the drum, and then the "fuser" uses heat to "melt" the toner-ink onto the paper, to produce the printed page.
You need to replace the drum.
Apr 07, 2010 | Konica Minolta magicolor 2430 DL Laser...
RE: CANON LB3340 LASERSHOT - WHEN PRINTING ON A5 PAPER PRINT IS SHADOW PRINTING AND NOT STICKING TO PAPER.
there is a "fuser" (hot roller) that is used to melt the toner onto the paper .. if its bad then the toner will not stick to the paper .. the fuser is after the drum and before the exit shoot ..
Feb 28, 2010 | Canon LASER SHOT LBP 3360 Printer
My DELL 3010CN is printing a thick black line on the right hand margin on all pages printed.
Often Toner sticks to fuser. When the fuser heats the toner comes off onto the paper. Should reduce over time unless toner is spilling onto the fuser in the same place.
Change fuser and toner
thanks
Apr 08, 2009 | Dell 3010cn Laser Printer
Toner prints onto adjoining paper in the mail.
maybe it is excess toner, or the paper type my be the wrong type to use, try some other type
Nov 17, 2008 | Canon imageCLASS D880 All-In-One Laser...
Noisy operation and black marks on left side of printed paper
vacuum out the waste toner passages that lead from the drum and transfer belt to the waste toner container. Toner is building up inside the transfer belt and/or drum and has no place to go except onto your paper.
Nov 06, 2008 | Samsung CLP-510 Laser Printer
An inch wide streak appears on the right side of a laser printer printed page.
If you can rub the toner off the paper it is the fuser.
fuser, the part of a laser printer that melts the toner onto the
medium. It consists of a hot roller and a back-up roller. After toner
is transferred to the paper, the fuser applies heat and pressure to
ensure that the toner stays on the paper permanently. This is why
paper is warm when it comes out of a laser printer.
For toner problem:
Do a half test as follows -
Print one sheet from the fold down tray, just as the trailing edge of the paper
goes into the printer open the toner door to stop the printer. Remove the toner
cartridge, are the marks on the paper that you can see in the printer? If they
are there the cartridge needs replacing.
Jun 03, 2008 | GCC Technologies Elite 12/600 Laser...
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Laser Printer
When the paper is fresh out of the printer, does the ink that looks okay smudge if you rub it with your finger? If so, it means the fuser is going bad. Otherwise, it's probably a bad toner cartridge that's leaking toner onto the paper.
Jun 12, 2006 | HP LaserJet 2100 Printer
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
