Question about Nintendo DS Console
When I plug my nintendo charger its not working
My nintendo is not working i spilt juice on it its not working and when i put the charge on its not working i have tried lots of things it is still not working i have dropped it on the floor and its not working but lots of liquid has gone into it is weel the main part is i cant charge it ihave put the charger in lots of sockets it always freezees every one has checked it i have stept on it before and it is a bit brakey it has lots of scratches on it.
    President:
  • 1,139 Answers
Sounds like your ds is in a sorry state. Unfortunately the DS is very delicate when it comes to fluids and if anything has been spilt inside it you have more than likely blown some circuitry on the motherboard. Usually the only way to fix this is to buy a motherboard or buy a new DS.
Posted on Jul 29, 2010
Hi my nintendo ds lite battery is dead and my charger is lost is there any other way to charge it without a charger?
You can try charging your DS lite using a phone charger. In order for this to work the charger must
  • Output around 5.2 volts
  • The end of the plug must look like the second plug from the left in this picture
When plugging this cord into your DS lite do NOT force it in. If you push to hard it may break the DS lite.
Jun 13, 2011 | Nintendo DS Lite Console
My ds isn't working because i spilt juice in it
I have seen many cases of this, you have probably busted the motherboard or the mechanism inside.Its sorry to say if the hairy guy at the repair store cant help, the only thing that can is buying a new DS.
Hope i helped :)
Aug 06, 2010 | Nintendo DS Console
Doesnt work plug in charger but it doeant charge &libht doesnt come on
I would suggest making sure the outlet you plug the DS into has power. Some outlets do not work unless the room's lights are on. If you have already tried that, I would suggest contacting Nintendo customer service at 1-800-255-3700 or going to http://www.nintendo.com/consumer/index.jsp as it could be a problem with the DS charging outlet or the DS charger itself.
Mar 16, 2010 | Nintendo DS Lite Console
MY DS LITE WONT CHARGE, THE LED FASHES ONCE WHEN I PUT THE PLUG IN THEN GOES OUT. I HAVE TESTED THE PLUG AND POWER SUPPLY BUT TO NO AVAIL. PLEASE HELP
i would reccomed a new charger, and if that doesnt work, then the charge spot on the DS is probably damaged, and you should take it to a game shop to have it shipped out and repaired.
Nov 15, 2009 | Nintendo DS Lite Console
Razr not charging -
New charger is needed - Razors are VERY particular about their type of charge - If it is a bad charger - You will see the battery indicator flashing red - and it will be empty - this is the phone saying pretty much that it cannot use this charger -
I have had ALOT of problems with razors and returned chargers - Try to scoop up an original - or take it to a location and test the charger first -
You can try to remove the battery and then put it back in - then try to charger it but i doubt that will work -
Get a new charger - TEST IT FIRST IN STORE!!!
Good Luck!
Jul 17, 2009 | Motorola Mobility RAZR V3
Ds lite suddenly stopped working
The orange light goes off when the battery has been charged to its highest capacity. After every charge, the batteries capacity is decreased. Get a new battery, that should do it.
Feb 28, 2009 | Nintendo DS Lite Console
Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Feb 05, 2009 | Nintendo DS Lite Console
Nintendo DS Lite screen is not working properly
I leave my DS on the charger all the time with no problems. You are going to get a lot of people telling you this, so be ready.
Anyway, way the DS dropped, stepped on, or had something spilled on it? That could very well be the cause.
Another problem could be the charger. Look and see if the charger is torn, has something on it ( Juice, sticky stuff, or something that really shouldn't be there), and by something on the charger, I mean something on the head of the charger that you plug into the DS. The wire could be torn up and frayed too.
You could also get the DS refurbished. This should correct the problem. Refurbishing is cheaper than buying a new one, refurbishing a DS costs anywhere from $70 to around $90.
Hope it helps~
Jan 17, 2009 | Nintendo DS Lite Console
Spilt juice on my sony ericsson
u r charging ic has been damaged u need to replace the board or check the battery output pins it must be 3.6volts
Jan 11, 2009 | Sony Ericsson K850i Mobile Phone
My ds charger plug is bent
The only concern is if the connectors inside the charging station is corrupted. The bending is simply the outer metal connection, then bending it back wouldn't cause any damage. If the problem is further inside the station, it needs to be replaced. Nintendo can replace it for you for an acceptable price.
Jan 03, 2009 | Nintendo DS Console
Nintendo DS Console Logo
191 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
