Question about Whirlpool Dryers
Changing dryer exhaust to side
How do I go about changing dryer exhaust to side ?
  • 478 Answers
There is a kit avalable for this purpose. It comes with a 90 degree elbo that requires you to remove the back wall of the drier. The kit comes with instructions to complete this change. you can buy this where appliance parts are sold.
Posted on Jul 29, 2010
Need to change back exhaust to side on model wed5500bw
There is a knock out on the side and you will need to get the elbow from the appliance parts store near you. If you need more help let me know. You will have to disassemble the dryer to do this.
Jan 22, 2014 | Whirlpool WED5500XW Cabrio 7.4 cu. ft....
How can I change my exhaust vent on my dryer from back to side exhaust
You can use this dryer vent periscope to turn the exhaust around to the way you want it.
Dryer vent periscope
May 21, 2011 | Dryers
I have an DLG3788 dryer,the heat comes on but only for a few seconds at a time and it continues this process
There are two thermostats in the dryer. They are located on the exhaust tube that houses the burner element and the ignitor. One is on the top half of the exhaust tube near the dryer wall and the other is on the bottom half of the exhaust tube toward the center of the dryer. The one on the bottom half of the exhaust tube in the one with the reset button. Before pushing the reset button disconnect power. The reset switch is between two wire leads that go to the thermostat. If you open up the right side access cover on the dryer, then you can see the exhaust tube. It is about 5 inches in diameter and (looking thrugh the right side access port), it will be sloping up from left to right as it runs from the front of the dryer to the back. You can see another exhaust tube further away from the port and lower down, but the one you are looking for is closest to you and higher up. If you look back toward the front of the machine (left), you can see two wires hanging down from the opposite side of the exhaust tube. The wires run to the thermostat which you can also see on a bracket standing off the exhaust tube. In between the two wire leads that run to the thermostat is the reset button. push it back in then try the dryer it should work now, good luck Tim
Feb 27, 2011 | LG DLG3788W Gas Dryer
The dryer will not get hot on any setting after I moved it into a new house. All that comes up is: Dry / Cooling. Is there anything I can do to reset or something?
Unplug dryer and the reset switch is between two wire leads that go to the thermostat. If you open up the right side access cover on the dryer, then you can see the exhaust tube. It is about 5 inches in diameter and (looking through the right side access port), it will be sloping up from left to right as it runs from the front of the dryer to the back. You can see another exhaust tube further away from the port and lower down, but the one you are looking for is closest to you and higher up. If you look back toward the front of the machine (left), you can see two wires hanging down from the opposite side of the exhaust tube. The wires run to the thermostat which you can also see on a bracket standing off the exhaust tube. In between the two wire leads that run to the thermostat is the reset button.pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minute operation if you can get to the right side access port.
Dec 25, 2010 | LG DLE2532W Electric Dryer
I would like to convert exhaust out the side of dryer instead of the back. My manual says this is possible, is this difficult?
No that is not difficult. You just hammer out the knock out on the side of the dryer and then install a 90 degree ell, some dryers have it insdie in the back, and turn the exhaust to go out the side instead on straight out the back...
heatman101
Apr 08, 2010 | Dryers
Need to change vent from rear to left side
why don't you just go to home depot and buy a longer flex hose?mike
Feb 19, 2010 | Kenmore 64942 Electric Dryer
I want the exhaust to be diverted out of the side of the dryer, how do i do that
You'll have to order a side exhaust kit. go to partselect.com and look up part# PS334300 comes with instructions good luck.
Aug 28, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Exhaust Need to install side exhaust on maytag dryer
There will be an indented area about 4 inches in diameter if your able to put one in easily. Other wise you'll need either a hole saw 4" or cut a hole in the side of the dryer but before you do make sure your inside piping will reach the new area you want to come from.
Another suggestion would be make a base for your dryer to set on 6 to 8" high cut a hole in the side of it and in the top where you can run the dryer hose through then continue on outside with the hose-vent.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Maytag Dryers
Dryer will not come on. i changes all my fuses and got a voltage tester and all that is fine, where can i find out about checking any fuses on the dryer itself?
Check the thermal fuse on the dryer.
Remove the rear panel.
The thermal fuse is located on the exhaust vent.
It is about 1 and 1/2 inches long and 1/2 inch wide. It is white in color.
It is at the left side of the exhaust vent outlet.
Mar 09, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
114 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
