I hooked up my dvr to my hdtv with the hi def cable and now I get no audio on my dvd player when I tried to watch a movie.
Cable company came out and helped me hook-up correctly. The best experience I've ever had with a cable company!
Posted on Apr 25, 2008
Cant figure out how to hook up the receiver to my phillips hi def tv and get the sound?
its old model, will not pass hd video, good only for audio. Connections depend on your equipment. If you use a cable box to watch tv, connect cable box audio out rca connectors (red and white), by an audio rca cable, to audio TV input on the back of the receiver. Now when you swith your receiver to TV input you get sound from cable box trough your speakers.
If you use DVD player: connect audio out of the player to dvd audio input of the receiver. Switch the receiver to DVD input, you have sound from DVD.
Jan 08, 2011 | Denon AVR-1403 Receiver
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
I bought a Sanyo 26 in lcd hdtv 7 months ago. No
Try explaining the problem to the manufacturer. They will help. They may change the software if needed. After the guarantee it will become a payable service.
May 24, 2010 | Sanyo DP46849 46 in. HDTV
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
How to hook up my dvd player to my cable box
Richard,
I would have to guess that you are hooking up a DVD recorder?
If you are then you take the video and audio cables out of the cable box and hook them in to the DVD R input plugs. The output wires go to the TV video/ audio in. Its just like hooking up a VCR.
Now if you are trying to hook the DVD player up to watch movies then you have to hook up the audio/video cables up from the DVD to the back of the TV into your Video 1/2 input. If you have the Component wires you hook them up the same way.
Now if your TV only has the one set of plugs (video/audio) then goto your local Audio/Video store and pick up the A/V cables that have the "Y" or "T" plug on one end.
I hope this helps you.
Mar 27, 2008 | Philips DVP5140 DVD Player
No sound coming out of back speakers when watching DVDs
Make sure you have set blu ray player out put to bitstream,if you have set to pcm for hd master audio and dolby true you need to have a amp to decode this and hook up with a hdmi cable.If your amp has hdmi in and out but no high def audio you may still get multi channel audio.
Hope this helps.
CABLE GUY.
Mar 06, 2008 | Yamaha HTR-5790 Receiver
How Do I hook up my Sanyo DVW -7000 To my Dishnetwork Box to record?
Connect the "Out to TV"video and audio on the DVR box to the "Video in and Audio In" on the VCR ...unless it's a single screw type connector on the DVR then hook THAT to the "In from ANT/cable" on the VCR
Sep 08, 2007 | Sanyo DVW-7000 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
