How to add record in access database using ADODC connectivity in vb6
  • 981 Answers
Register with the major index or indices using your favorite ADO template, and use methods (.RecCreate, typically) on them to create a new record with some set of well-checked values; send an ADO heartbeat; enjoy.
Posted on Apr 24, 2008
Describe your MicrosI use Adodc for connecting a database but how can i display records to listbox?oft Problem
Yo have to bound the listbox to you Adodc controls. Let say's:
Assuming that you have already set you Adodc contrl to assign a connection in one of your database then use the code below to bound your listbox data source to your Adodc datasource.
Set Listbox1.datasource = Adodc1.datasource
Thanks
Aug 01, 2009 | Microsoft Visual Basic 6.0 for PC
I want to programaticaly modify an SQL statement in VB6
If I remember correctly you need to call ExecuteQuery or something similar otherwise it does not update the database.
Regards
GeWiz.
Jun 16, 2009 | Microsoft Visual Basic Enterprise Edition...
I have a visual basic program in which i have to display the record from access table by using connection of adodc.and then select record from datagrid will display in another form. plz reply as soon as...
hi,  you may visit this site www.kidwaresoftware.com/ and download all free visual basic source codes with tutorials..  One of the source code will solve your problem.    However their paid Visual basic source codes will most powerful.    As I am total deaf and no source to communicate others... I want to share the  payment source codes with tutorials from  www.kidwaresoftware.com/.  Are you ready... If you download the  source codes with tutorials (only Fee for it) I will share with you.    esakkisivaganesh@yahoo.co.in
Apr 08, 2009 | Microsoft Visual Basic Enterprise Edition...
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Write into excel format
Your code does not save in access format it just makes a copy of existing file. You need to open table by table and export data using csv format.
It can be done using access OLE to export, or
write some VB code to access the database tables via ODBC and save row data to csv file
Feb 17, 2009 | Microsoft Visual Basic Professional...
Migration from single machine to multiuser environment
have you made sure that the ADODC path points to the machine that holds the database on a remote path for example (\\ComputerName\c$\Data\) and that it isn't a local path. (C:\Data\)
Dec 15, 2008 | Microsoft Windows Server Standard 2003 for...
Data storage form
If you give me a bit more detail about what you're trying to do, I would be happy to help.
I think you are interested in building a form that will add records to a database. Am I correct?
Tell me the language you are using, and the type of db. I know you are interested in SQL, but perhaps you are using Access.
If I guessed you are trying to create a web form that adds records to a database would I be correct?
The more detail you can offer, the more I can be of help.
Best Regards,
airoff (Alan)
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Accessing data
Dear reader
Place an ADODC control on your form in VB.
In the properties of the ADODC control goto the TAB General.
click "Use Connection String. With the button Build you can point to your database.
Thats it.
With the following code you can connect to db:
With Adodc
.RecordSource = "SELECT * From YOURTABLE"
.Refresh
End With
Now you have the table in the adodc control.
you can now do this:
Label1.caption = Adodc.Recordset!YOURFIELD
YOURTABLE = the name of your table in the database.
YOURFIELD = the fieldname in YOURTABLE you want to show.
Kind regards Fred.
Jul 04, 2008 | Microsoft Office Access 2003 (077-02871)...
RUN TIME ERROR 2147217842(80040e4e)
have u check the net framework version of the os ur using
Dec 18, 2007 | Computers & Internet
MS Access 2003 Development - Format Problem
Hi, the difficulty to solve your problem is that we are not familiar with Appx. I have faced this problem numerous time, but usually it was from Excel to Access. Now if you can transfer it to Excel then you can change the format in Excel to Text and import it into Access. I have also read a little of the Appx manuals and it says there that you can work with ODBC, are you using it? ODBC will create a connection between the APPX application Database and Access, you should be able to do your queries directly from the ODBC connection without the need to import the table. Here is a PDF manual of how to set it up from their website: http://www.appx.com/ftp/appx/documents/manuals/appx/appxodbc/current/appxodbc-manual.pdf I hope it helps, let me know and I will try to do my best to solve your problem. Daniel
Aug 10, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
