Question about AEG Lavamat 72640 Front Load Washer
Hi, when my machine starts to spin it is very slow, it wont go into a hard spin to get rid of the water, when this first happened I wasn't around to see what was happening and the clothes were soaking wet. I then turned it to the spin mode and it just turned slowly. The drum seems to be ok, it still turns around but doesn't go around at the set 1200rpm. Any ideas would be greatly appreciated 8-)
  • 106 Answers
Try changing the running capacitor or stating carpacitor
Posted on Jul 28, 2010
Washing machine stopped working. The lights come on but water wont start filling
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 25, 2011 | Washing Machines
Soap gets clotted is soap dispenser. Dishes greasy and dirty after cycle.
Hi, the soap is clotting because there isn't enough water being sprayed around inside. The water spray washes the soap out of the dish, if all is working well. My machine had the same problem. I had sufficient water level, but the spray head wasn't spinning very well. I found the end-most hole in the spray bar to be plugged. It is the end hole that provides a jet that makes the head spin. I cleaned a bunch of debris out of the hole and the machine started working and cleaning like it was new.
Jun 26, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
Kenmore 29832800, top loading will spin, but will not fill (or start to) machine on wash or rinse cycle - spin feature is all i have
heatman101
Apr 17, 2011 | Kenmore Washing Machines
Wont fill with water. It will spin not sure if it will run whole cycle
heatman101
Apr 13, 2011 | Maytag LAT2600A Top Load Washer
The machine hums when started but will not fill with water or spin
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Mar 14, 2011 | Washing Machines
Why wont the washer start filling ?
heatman101
Sep 25, 2010 | Kenmore 23822 Top Load Washer
Hi there, i have a hoover elite 1220 i think 7.5kgs i brought it second hand of ebay and it has been a good machine but it has started to play up lately. It washes all on the normal cycles and stuff i...
Following will be the causes for water not draining properly
1.There is a motor/Pump which operates to to drain the water check whether that motor is working.
2.Check filter and clean it
3.Check the drain pipeline whether it clear
4.Check the inlet valve of the machine Sometimes the drain works properly but the inlet solenoid valve will not hold and the water keeps coming in and fills the drum
Thank You
Sep 02, 2010 | Hoover HTC243 Top Load Washer
Washer wont fill
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Washer leaks and keeps shutting off when it starts to spin.
 it sounds like your washer is not draining before it starts spinning. the machine should not have visable water in it when it starts to spin. make sure there is no water in the machine and that it is draining properly.
Jan 27, 2009 | Kenmore 23822 Top Load Washer
WASHES BUT WILL NOT SPIN
If your washer pumped out the water then your motor and water pump are both still working. Your washer has many sets seals and bearings that could have gone bad. This problem happened to my washer in the past also and i was able to just spin the drum around a few times and then shut the lid on the spin cycle. It started spinning slow but was able to make speed quickly. The oil seal on the gear case did start leaking though. This should be a cheap fix that could be done by most people with some mechanical ability.
Feb 14, 2008 | Washing Machines
AEG Lavamat 72640 Front Load Washer Logo
130 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
