Question about Canon MP520 All-In-One InkJet Photo Printer
Hi, I just bought a new Canon MP550 and I try to install it and it says my printer is not detected. I uninstalled it and rebooted and installed the drivers from the internet but that didin't work eather. Kind regards elke
  • 10,421 Answers
Installation
uninstall the printer completely and then try installing it back
Aug 23, 2008 | Canon PIXMA MP470 All-in-One Printer
I just bought and installed a Canon Pixma E510 When I try to run my image garden, I receive the following message:An internal error has occured Exiting this software
Try uninstalling all Canon software. Then disconnect your printer and reboot your computer. Then install the software again with the provided CD/link/instructions and try starting the program again.
Dec 02, 2013 | Office Equipment & Supplies
Canon mx310 printer is offline and won't print from computer
Hi Harry,
Try re-installing the printer again.Disconnect the printer completely from your PC.Uninstall the printers software from your PC and then reboot it.
Insert the installation disk and run setup to install a fresh the printers driver.If you don't have the installing discs,download the drivers from this canon support site.Select the driver that corresponds with your Operating System[Windows XP,Vista etc].
Hope this helps.Thanks!
Please rate this answer.
Nov 20, 2011 | Canon PIXMA MX310 All-In-One Printer
I want to use my scanner of canon mp140 series printer but it cant scan the documents, i dont no why
Hi
Go to the control panel and the install program list you see, check the install canon printer driver & uninstall that driver. after installing the driver reboot you system and follow the below instruction.
1) Put you canon driver CD in rom.
2) and duble click the setup.
3) Choose the complete installation option.
4) and wait for intallation.
5) after that installation finish reboot your computer.
6) Go to the control panel and select the Scanner and Cemra option.
7) You find your install scanner hear duble click that one and use the scanner
Cheer
Aug 11, 2011 | Office Equipment & Supplies
Hard drive failure required rebuild of XP Home on Dell computer. XP Home updated to SP3. Canon Multiplass F80 printer will not now work. I downloaded latest XP drivers from Canon web site, but installation...
I found that some Windows Plug and Play services were note running and were set to start 'manually'. I started those services which seemed related to Plug and Play, and the installation went without further errors.
May 11, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Help
Assuming no hardware issues with your printer/PC, a few ideas you could try:
1. Update your Windows specifically your USB drivers;
2. try the rear USB port if on a desktop;
3. uninstall all the USB devices in your Device Manager, reboot and allow Windows to auto detect/install the USB;
4. download latest drivers and re-install (of course all instances of the PIXMA iP3000 in your Printers & Faxes must have been initially deleted/removed.
Hope this be of initial help/idea. Pls post back how things turned up, your OS, what have you done so far or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 29, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Hey
Try this:
1. Uplug USB cable from printer.
2. In Control Panel > Printers UnInstall all printers then reboot.
3. Install drivers/software for the printer.
4. Plug USB cable back in and the PC should find it now.
Hope that helps...
Geno
Mar 18, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Ip4200 - printing issues!
Hi, Perhaps you can try: remove the USB connection of the printer; uninstall and remove all drivers of the Canon IP4200; reboot your PC; plug in your usb to the PC from the printer; power on your printer; let windows auto detect "New Hardware found"; let windows auto install drivers; test print. If after plugging in your usb and powering your printer Windows did not auto detect "New Hardware found", it's possible that your printer's usb cable is defective. If Windows auto detected the Canon IP4200 and auto installed all the necessary drivers but failed in the test print, repeat above steps but instead of auto install, use the original CD driver and not the new drivers (Let me choose which drivers I want". RESET - User manual is available from the Canon site. There are 2 versions, 1 is a Quick Start Guide in pdf and the other is a User's Manual (On-Screen). Both does not say anything about reset, however you may want to google "fix your own printer" and variations of resetting all sorts of printers are available. Some works, others are ... well you can always give it a try. Or in the On-Screen Manual,you can also try the Troubleshooting/Printing Does Not Start. Another thing that you can try is installing the printer in another PC using the old CD drivers and see if it works. If it does, then it is a driver issue with the new PC. If it does not, you're back to reset . Hope this be of some help to you. Good luck and kind regards.
Jul 30, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MP520 All-In-One InkJet Photo Printer Logo
146 people viewed this question
old marine
old marine
