Question about Averatec Computers & Internet
My computer(laptop) connects wireless ly , but does not pull internet up. when i checked the ip address there was some letters, numbers and symbols w the normal ip address .it would not ping
    Novelist:
  • 155 Answers
Hello
I think there might be a problem with your connection.All you need to do is to get your laptop configured correctly so it can work perfectly with your internet.
THANK YOU
Posted on Jul 28, 2010
  • cshoe44 Nov 12, 2010
    What kind of a BS answer is this? Of course there is a problem with the connection. That's what the person said. Of course all is needed is to get it configured correctly. That's what you are supposed to be answering.
I cannot connect to the WFC because it needs the ip adress and the connection fails
Click start type cmd press enter you will be in DOS mode
type in ipconfigpress enter you will see all of your internet connection details type in your default gateway ip adress into your internet search should read something like 10.0.0.138
Your IP Address should be thought more as your computer's phone number than it's address, if you have multiple connections, you have multiple IPs if you dont have a connection, you dont have an IP.
Without further delay If you need your computers IP address:
This will work in almost every case, it simply requests the website's server to tell you what your IP is. http://whatismyipaddress.com/
I have included a link to make things easier.
If you are in a network and need your computers local address.
Hold the windows button (looks like the windows banner, usually between left ctrl and left alt) and press 'R'.
A box will display, and type in "cmd.exe" and hit enter.
The 'command prompt' will display, a black screen with white lettering.
Simply type in ipconfig. This gives information on all your internet connections.
Look for the line "IPv4 Address".
If you need to find the IP of a current connection you can type (from the command prompt) "netstat".
This will give you all your current connections.
To identify a specific one, the easiest way is to run it before you establish the connection then again afterwards.
Change IP Addresses
Your IP address is a series of numbers that identify your specific computer on the Internet.
If, for some reason, you want to change your IP address, you can do so without going into the command prompt.Click "Start," "Control Panel," "Network and Internet" and "Network and Sharing Center."
Click "Change adapter settings."
Right-click the network you want to change and click "Properties."
Click the "Networking" tab.
Put a check either next to Internet Protocol Version 6 (TCP/IPv6) or Internet Protocol Version 4 (TCP/IPv4) and click "Properties."
Click the radio button next to Obtain an IP Address Automatically if you want Windows to assign one, or click "Use the following IP address" to manually change it.
Enter the requested information and click "OK."
Mar 01, 2014 | 2wire Wireless-G 802.11g ADSL Gateway
Belkin Wireless router
Is the laptop connected to the router wirelessly? because that can be the porblem if that laptop is not connected wirelessly it wont be working, so make sure that the laptop is connected to your wireless network...
Hope that helps..............
Sep 03, 2008 | Arris Wireless G Broadband Router (wr850g)
Cannot get wireless service
Power on the laptop computer and wait for the operating system to boot.
Right-click the wireless Internet icon in the lower right corner of the desktop.
This brings up a new pull-down menu.
Select "View Available Wireless Networks."
This brings up a selection of different possible Internet connections that are in range of the computer.
Select the wireless Internet connection you want to use.
If a password is required, you need to type it in now.
Wait for the laptop to connect to the Internet.
In a moment the computer is going to state it has successfully connected to the Internet.
click Start, Run type in cmd and click Ok to bring up a command prompt.
Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100.
Check your wireless connection properties under My Network Places.
Right click the wireless connection icon and choose properties.
From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked.
if still no joy
Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok.
For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
hope this helps
Sep 15, 2012 | Computers & Internet
Can 3 computers (1 desktop and 2 laptops) share the same IP address?
No. Each device connected to a network must have a unique address so that data can be properly routed. If you want to share an Internet connection among several computers, you need a router. The router provides a single IP address connection to your service provider on one side. Then each computer connected to the router, wired or wireless, gets its own internal IP address from the router. As data comes over the Internet, the router takes care of getting it to the proper computer.
Dec 06, 2010 | D-Link DIR-615 Wireless Router
I have a compaq laptop and a wireless adapter that has been connected to the wireless network but I am not able to pull up anything on the internet. We have another computer that is able to go onto...
If you are able to connect to internet from the PC by conecting it with a cable then the issue is surely with the wireless setup, please check the IP address on the laptop is it coming in the rannge of the IP of your desktop and router you can check it by go to start menu from the bottom left of the computer and type "run" there it will open the command prompt, type "ipconfig" there and you will be able to see the IP, the reason can be you have some wireless security on your router and same code need to be entered on the laptop to completely connect and access internet
You can follow the below link also it will help with wireless connection
http://setup.belkin.com/guide.html
Let me know if this will help i can provide more info on the same
All the best
Regards
Nov 30, 2009 | Gateway Belkin F5D7230-4 802.11g Wireless...
We have a Linksys G Router. It works fine on my son's (Host) computer. My work laptop will recognize the wireless network but will not connect. My home desktop will not recognize the network. What are we...
There are wireless networking capabilities of the gateway that will prevent or allow specific MAC Addresses from connecting to the network. Go into the wireless settings and adjust the settings to accept the MAC address from your work computer. To find the MAC address from your computers network adapter go into a command prompt by typing cmd in the run box and typing "IPconfig /all" in the window. The MAC address is there it may be called Physical Address. It is always a 16 set of number and letter combinations divided by ":" between every 2 sets of number / letters. On your home desktop this same window will help you diagnose the problem. Your son's computer will help you with this, do this on his as well and compare the IP address with your home computer the address could be something like "192.168.1.?" the last number is going to be unique if the first three numbers match. If the IP address on your home computer doesn't match the first three octets "192.168.1" it will not get out through the gateway. If they don't match you can force it to be on the same network by setting up a static IP address by opening up the Control Panel / Networking icon and finding the icon for the network adapter that you are using and opening it up and clicking on "Properties" and clicking on IPv4 and clicking properties and clicking on Specify IP address and typing the first three octets of your son's computer and adding a fourth number that isn't "0" or "255". You can use any number between those two numbers except those numbers, and isn't the same as your son's IP Address or the Default Gateway which is the Linksys. The "Subnet Mask" will auto install but will be "255.255.255.0". The default gateway and DNS server will be the IP address of the Linksys which most likely will be "192.168.1.1". Click "Ok" on all the open dialog boxes and the computer should be able to get on the internet.
Sep 17, 2009 | Linksys Wireless-G Broadband Router
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Cant connect to the internet.
Click on Start and type CMD. Open CMD and type ipconfig. Check out the IP address V4 for the Local area ethernet adapter or wireless area adpater depending on wireless or wired connection. Any ip address other than of the class 169.254.x.x shoud be considered good. If you have an IP address is any other number other than the above you have a good IP address. to test the internet connectivity type PING www.google.com. If the results are Packets sent 4 Recieved 4 Lost 0 then the issue could be due to Internet Explorer bing corrupt or a firewall blocking the internet access. Power off the computer. Power on the system and as soon as you see the Dell logo please tap the F8 button 3 - 4 times. You'll get to teh Advanced Windows boot option screen. Select safe mode with networking and see if the internet works in the safe mode. If yes then it could be the firewall. Uninstall you antivirus and check.
Apr 02, 2009 | Dell Studio 1537 Laptop
Network did not assign a network address to the
Hi there, the only reason it doesn't work it's because the wireless key is not correct. It usually shows limited connectivity when the wireless key is not correct. Even just a letter upper or lower case will cause the problem. Since you are connected with the other computer go under the Router settings and double check the wireless key. Check what kind of encryption the router is using, make sure your wireless adapter can support it.
Apr 02, 2009 | Dell Vostro 2510 Laptop
Dell Laptop is not pulling IP address
Connect it directly to the modem with the ethernet cable first...Windows will configure the Dell...then the wireless should work.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
