Question about Adcom GFA-5300 2-Channel Amplifier
Channel problem power does not come on and i do believe there is a channel out
  • Adcom Master
  • 5,515 Answers
It's almost certain the two are connected. I suspect that one or more of the devices on the heat sink has shorted (acting like a piece of wire) and has blown the fuse.
Posted on Aug 03, 2010
B&K AVP2000 left channel not working
Yes amps buzz when something gets near them - say a pen or probe and if you know what it is safe to touch a finger! Fortunatly for you the left channel is the same as the right. So if you believe it's the pre-amp work backwards from the where the power amp connects to the pre-amp, going through the pre-amp stage by stage - prodding the parts. Remember a buzz in the right a buzz in the left! No buzz in the left but one in the right fault found!
Ignore the power supply it's nothing to do with that as it's common to both channels.
Dec 30, 2012 | Audio Players & Recorders
Hi i have a nordmende tv and was working until it was plugged out of the mains now it stuck on standby and i dont have remote its an nw32lqt any ideas for easy fix i ve tried letting capicators drain no...
while the TV is on standby, press the channel + or channel - button on the TV and the TV should power on.
If TV doesn't power on after pressing the channel button, then it means your TV is having a power problem. But I don't what to believe it is a power problem.
Let me know if press the channel button does not power on the TV so that I can explain further on the cause and way to fix the problem.
Yours sincerely.
Elect_Comp.
May 16, 2011 | Televison & Video
We have a 4 year old Visio HD TV. Recently we had time when both the HD channels and going up and down using the channel surf buttons did not work. The low Def channels would work and entering the channel...
I don't believe that it is cost effective. BUT, if you have Comcast, you will now need a cable box to watch most channels now. I believe they stop at about channel 12 without the box. It's their way to stop cable thieves, but it's an inconvenience for the rest of us.
If this isn't the case, you might want to try to contact Vizio tech support www.vizio.com. or try to reset the TV - unplug the TV, press and hold the power button for 30 seconds, repeat. Plug it back in and see if it helped.
Apr 22, 2011 | Televison & Video
One of My speakers does not work, When I switched the speaker wires the problem followed. I believe maybe a blown channel. """please help"""
Yes, one of the power amps has probably failed. If the channels are seperate, then another possibility is a bad input connector. These do get broken when cables are tripped over.
Nov 08, 2009 | Marshall Amplification Marshall MG250DFX...
My tv is stuck at one channel. Which controller board has to be replaced? The Key controller,LCD controller, or what?
I got the same problem, TV stuck on one channel, what I did was, I remove the cable (fron the back) for a minute and then reconnect, work perfect, well, better than try to return the bloody thing.
Good look with your.
D.
May 01, 2008 | iLO 3200 32 in. LCD Television
I dont know how many watzz is my amP!
200 X 4 does mean 200 watts times 4 channels. In other words each channel pushes out 200 watts. I believe u have a total output power of 800 watts but check with ur manual and if u do use that much power make sure you check for overheating, specially if its used for bass. Soundstorm amps cant take much of a beating so be careful.
Jan 27, 2008 | Soundstorm F200.4 Car Audio Amplifier
Video mode
I went to add/delete channels in my menu on my symphonic and it let me scroll through the channels, make sure you have them all set to add (by pushing the volume buttons to make them light blue instead of purple)....after adding all of your channels (or just the one if you use dish) just power the tv off while on a channel and then power back on and you should have tv.
Jan 12, 2008 | Symphonic ST419E TV
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Sep 21, 2007 | Olevia LT32HVE 32 in. LCD Television
Adcom GFA-5300 2-Channel Amplifier Logo
100 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
David Burbee
David Burbee
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
