Question about Roxio Easy Media Creator 7.5 for PC
I am using Roxio Easy Media Creator 7(Build ENU) and I am having problems with the Media Editor. The problem occurs when I attempt to use DVD Builder to make a DVD. When I Add New Title the DVD Disc Project size shows a project sizes, but the Menu Editor and the Production Editor does not display a menu are the files I have selected. Since the Menu Editor and the Production Editor does not display a menu are the files I am unable to selected files to edit. . I am also unable to Add to Selected Title. Previously I was able to use the application to build and burn DVDs. I am using Windows XP with an IntelĀ® PentiumĀ® 4 CPU 2.80GHz
Try uninstalling IE7.
Posted on Apr 25, 2008
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Roxio media creator 7,closes when i go to burn dvd
Do you have sufficient RAM and hard drive space? This product needs lots of resources and your hard drive needs to be defragmented otherwise problems like this will occur. It just runs out of space to do things and gives in often with having enough space to tell you what has happened.
Jun 07, 2009 | Roxio Easy Media Creator 7
Wont let me edit
What you need is Video editing software, Roxio Easy Media Creator 7 is only a way to put everything together and write to a CD or DVD.
May 20, 2009 | Roxio Easy Media Creator 7
I seem to have misplaced disc 2 of Roxio Easy Media Creator 7 - disc 2 contains the content. I have Disc 1 which is the main applications. I have to reinstall the program because of a computer problem but...
Below is a download for the full version of Roxio Easy Media Creator 7.8
You can get rid of that disc, and download the one from the link. You can burn that to a disc after its done if you want for backup purposes.
Enjoy, Thank you for choosing Fixya!
Mar 21, 2009 | Roxio Easy Media Creator 7
How can I retrieve the serial number for Roxio Easy Creator 10
Log on to this website and provide proof of purchase; I'm sure they'll be happy to help.
Feb 21, 2009 | Roxio Easy Media Creator 10 Suite
Can't install Roxio Creator 2009
There is a patch from Roxio to resolve this error!
Feb 05, 2009 | Roxio Easy Media Creator 10 Suite
Have Roxio 7 and want to install it on Windows Vista
Easy Media Creator 7 is not supported on Vista. Easy Media Creator 9 and above are only supported. Anything lower may be able to go onto Vista, but Tech Support is not going to be able to assist you if you have problems.
Jan 24, 2009 | Roxio Easy Media Creator 7
goto this site and reinstall it for free or goto for the driver.
Feb 02, 2008 | Roxio Easy Media Creator 7
DVD RW - Installation Problem
Ok. What I am going to suggest may seem like a daunting task but if you are careful and do only what I suggest you should be ok. The first thing you are going to have to do is manually make a change to the Windows registry to fix the permissions. 1. Fix registry permissions a. Click on "Start" choose "Run", then type "regedit" and click "OK". b. In the Registry Editor, click on the "+" next to "HKEY_Local_Machine". c. Now click on the "+" next to "Software". d. Right-click on the key (folder) called "Roxio" and choose "Permissions". e. Make sure that "Administrators" and "System" have checkmarks for "Full Control" - "Allow". f. If you had to add those checkmarks, click on "Apply". g. Click on "Advanced". h. Put a checkmark in "Replace permission entries on all child objects with the entries shown here that apply to child objects". i. Click "OK". j. Click "OK" again. k. Now close the Registry Editor Next, you will have to uninstall the Roxio software. 1. Remove Roxio Easy Media Creator 7 a. Go to Start--->Settings--->Control Panel--->Add/Remove Programs b. Select Roxio Easy Media Creator 7 and select "Remove" c. Once the uninstall is complete, reboot the computer. 2. Reinstall Roxio Easy Media Creator 7 a. Insert the CD and install as you did before and then reboot. If you have any issues uninstalling the Roxio, go to the following link to download the Microsoft Cleanup Utility... Run the utility after the unistallation attempt and then reboot and reinstall Roxio. Hope this helps. Good luck.
Jun 19, 2007 | LaCie 8x DVD+/-RW USB 2.0 External Dual...
Open Questions:
Roxio Easy Media Creator 7.5 for PC Logo
170 people viewed this question
Top Roxio Computers & Internet Experts
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
