Question about Dometic Rooftop RV Air Conditioner
I live in AZ. my RV rooftop AC works as long as outside temps are under 95 degrees then it trips the braker. can low refigerint or outside fan not in the shrowed cause this?
  • 674 Answers
The fan not in the shroud may cause this. Are you sure the condenser fan is even running or running at the right speed? If its not running, the compressor head pressure will build up until it possibly pops the breaker.
Posted on Jul 29, 2010
  • flh86inch Aug 28, 2010
    yes, the condenser fan is running but I think the fan blade may not be ajusted right in the shroud, would I get more air flow if it was?
  • Brian Niten Aug 30, 2010
    Yes, you probably would get more airflow if the fan isn't sitting close enough to the shroud and you adjusted it. A restriction in your refrigerant line may also cause it to do as you describe.
Outside heat stops ac operation
clean coils seee if it makes a difference. all air-conditioners are designed by mfg. to run in a ambient temperture of 95 degrees. after that they lose effiency.
Feb 06, 2014 | Dometic Rooftop RV Air Conditioner
Runs/cools great unless outside temp gets in high 80s
try replacing capacitors. or communication cable issue to that a/c
Jun 25, 2013 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner works as long as outside temps are under 95 degrees then it trips the braker. can the outside fan not ajusted in the shroud right or low refrigerent cause this.
Hi, most all a/c that are on the market are designed for that exact temperature, 95*F. After that they will loose up to 40 % of there efficiency. But tripping the breaker indicates it is working to hard and over ampping so there is a problem up top. It may just be a very dirty condenser coil which will cause this unit to build the high head pressure causing the compressor to draw more amps then normal and will trip this breaker. If you can, go up and remove the cover. Watch it run to see if the condenser fan motor is running good. Look at the coil for dust and dirt build up. Its a good sign that it cools at 95* F, so I believe its just a dirty condenser coil. This will cause your internal pressures to peg out in temperatures at 95 and above!.Even if it looks OK, kill the power and run a water hose up top. Was out this coil and watch the dirt run out of it. I have seen the head pressure on units at 400 P.S.I. with a dirty coil and after washing drop 200 P.S.I!! If the fan is running good, this will be your problem. Before you go up, take a good flat heat screw driver along and when you are done cleaning this check the electrical box, and make sure all of the main connections are good and tight. Check to see if there are any signs of burned wires as this will also trip breakers as when loose they will create heat and burn the ends. This will solve your problem. You may want to check the 2- wires at the breaker also, just be sure it is off and tighten just the wires that go into the breaker as they will be dead at that point. Please use caution!. Doing all of this will take care of your problem, I am sure unless you have a internal compressor problem which I don't believe you do. Please don't forget to rate me as I know you will be kind to me. Please keep me posted and I will be checking up on you also. I wish you the best.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Aug 28, 2010 | Dometic Rooftop RV Air Conditioner
Air Conditioner trips the 110v breaker, only when the outside temp is above 90 degrees. Unit has been checked several time and the circuit board has been replaced, but has fixed the problem of tripping the...
'Breakers' - are tripped because they are exceeding their amp limits.
The 'hotter' it gets outside - the 'harder' your AC has to work - and under normal circumstances this is not a problem - but when you have a fan motor or a compressor that is starting to 'break-down' (electrically) - often the AC's amp draw will exceed the limits of the breaker - thus 'tripping' the breaker.
I would suspect either the fan motor or the compressor is causing your breaker problem.
Eventually - the component (either the fan mtr or compressor) that is 'going bad' will go out completely and your breaker will 'trip' and not stay on when you try to reset it.
At this point you will need a Service Tech to determine which one is bad.
There is a possibility that your condenser coil (the one that blows hot air) is 'dirty' which will also cause a problem similar to the one you have - but it is less likely.
Also - if you've had the AC 're-charged' lately - it's possible you are in a 'over-charged' condition - but again, this is not very likely.
hope this helps.
Jun 06, 2010 | Dometic Rooftop RV Air Conditioner
Rooftop RV Air Conditioner: temp outside 90 or above. compressor kicks off ....
It sounds like maybe an overload for the compressor is tripping and resetting once the compressor cools. Possibly due to a low charge.
May 03, 2010 | Heating & Cooling
How cold should it be in rv with two low orofile
Most AC units only change temperature approximately 20 degrees F from ambient.
Aug 17, 2009 | Dometic Rooftop RV Air Conditioner
Circuit breaker overheating on rooftop ac after
Possible overcharge or bad breaker. You need to check the amp draw for the unit. If you draw under full load amps and trips breaker breaker is bad.Rus
Jul 13, 2009 | Dometic Rooftop RV Air Conditioner
Ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
My Duo Therm Runs good until the outside Temp. Reaches about 75 dregees Then starts kicking off the braker. What would cause this?
Too many things on the same circuit. Try turning everything electrical off but the ac and see if it stops tripping the breaker.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
579 series, 13.5K BTU Rooftop trips AC circuit breaker in hot weather...
Is your condensing unit located in a well ventilated area and have an ample space, atleast a foot, from the rooftop flooring? Just make a check that free flowing outside air properly ventilates the condensing unit specially on high ambient temperatures. Hope this would solve your problem
Sep 16, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
178 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
