Question about Dryers
My dryer is no longer putting out hot air only cold. Is their a quick fix to this problem. It is a maytag performa model pyg2300aww
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Your dryer most likely has a bad: 1. Hi Limit thermostat 2. Heater Element 3. Thermostat. You will need a meter to check these. No quick fix. Sorry.
Posted on Jul 31, 2010
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
I have a Maytag performa poropane dryer. It states the input rating at18000 btu per hour. I have a 5/8 inch OD flexible gas line at 48inches long it is rated for 75001 to106000 btu/hr . Is this the right...
Hi and welcome to FixYa, I am Kelly.
There is nothing wrong with using a larger flexible gas line than is required. We used the 5/8 OD lines most of the time as they were much more durable than the smaller ones. The line you have is fine.
Thanks for choosing FixYa,
Kelly
Feb 09, 2011 | Maytag Dryers
My Maytag Performa PYG2300AWW dryer quit working today. 1st we noticed it wasn't dying clothes, then there was a smell. We thought the lint was clogging it up, so we vacuumed everything out. Now it won't...
This could be the thermal fuse or Hi Limit thermostat possibly a few other components. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the troubleshooting procedure. It's a different model but testing and components are the same.
Mar 27, 2010 | Maytag Performa PAV2200
Maytag performance pyg2300aww is making a screaching sound
HOW DO YOU CHANGE THE DRUM BELT ON MAYTAG DRYER MODEL PYG2300AWW
Nov 23, 2009 | Maytag PYG2300A Gas Dryer
How to replace heating element Maytag Performa gas dryer pyg2300aww?
Your model number indicates a gas dryer. It does not have a heating element. It has a glowbar igniter,a flame sensor and a gas valve. Either the glowbar igniter is bad or the flame sensor or the gas valve coils or the thermal fuse.
Jun 22, 2009 | Maytag Dryers
Maytag performa washer hot/cold now reversed
Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
Feb 26, 2018 | Maytag Performa PAV2200
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
My maytag performa gas dryer model # pyg2300aww gets warm but takes four cycles to dry.
clean your dryer vent going from the back of the dryer to outside also run a lint brush down where you put the lint screen in if this does not help replace your coils
Dec 29, 2008 | Dryers
Maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Mar 18, 2008 | Maytag Performa PAV2200
Dryers Logo
206 people viewed this question
Top Dryers Experts
Marvin
Marvin
