Question about Minolta DiALTA Di183 Copier
Copies have black streaks and "double printing" meaning that the image is repeated much lighter a few inches over
  • Minolta Expert
  • 1,326 Answers
The two possible solution is that you need a new drum cleaning blade and maybe a new OPC drum with it or it maybe that the upper fuser unit is worn out or dammaged. Look in thos two spots. Good Luck
Posted on Jul 29, 2010
I have a hp 3030 printer and when I replaced the ink cartridge it started making black streaks accross the paper, every 2-3 inches and there is a double image of the picture being copied.
Hi:
After replacing the cartridge it is mandatory that you do a cleaning cycle and head alignment to insure the cartridge is aligned properly for printing.
Jul 14, 2011 | HP Office Equipment & Supplies
When I make a print, the black color repeat 2 times and color geting lighter and lighter about 3-inch under previous paragraph ( I think it is the circumference of the imaging drum). I also found the...
If this problem is only happening with the black drum, it sounds like the drum is not getting cleaned correctly, and the residual toner is staying on the drum and being reapplied to the paper again. Replacing the imaging drum unit should take care of your problem.
Aug 06, 2010 | Dell 5110cn Laser Printer
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Printing quality problem
HELLO! IF YOU ARE USING A GENERIC DRUM OR TONER, YOU WILL HAVE COPY QUALITY PROBLEMS
Jan 14, 2009 | Brother IntelliFax-2820 Laser Fax
Double ptinting
try to clean the upper roller on heating section the final stage of the machines if the image is seen to be of the first objected copy this solution is only if you observed that the image of the previus object (source paper) is printed on the next copy or it repeats printing the lines.
and if it so replace or fix the new oil roler in heater unit.good luck vote me pls
Aug 27, 2008 | Canon NP 7130 Black and White Copier
Words Copied Multiple Times
Yes Cartridge problem is what causes double imaging 95 % of the time, there is a rubber blade in the drum unit that wears and doesn't clean off old image from drum. Have known this fault to be fuser at times, the way to tell is to get a print to stop half way threw machine by openning door during print, remove cartridge and look at print, you want it to be stop before the fuser(hot bit) but after the drum, image still rubs off if pre fuser and then you can see if defect is present before paper travels threw the fuser, but in your case I think you will find it is not the fuser it is toner cartridge.
Nov 24, 2007 | Office Equipment & Supplies
Minolta DiALTA Di183 Copier Logo
74 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
